need advice on putting a ats or jdm 4.7 final drive in a ys1 cable trany
Old Jan 29, 2003 | 12:36 PM
evilxkid's Avatar
Default need advice on putting a ats or jdm 4.7 final drive in a ys1 cable trany
i want to put a ats final drive in my ys1 cable trany, it has a non lsd open dif and i'm not to shure if my ring gear will fit. would i have to use a gsr dif. i don't plan on changing the dif if i don't have too (it has a phantom grip in it. some people dog it, but haven't even used one before.). i'v searched a hunddred time's and never found the info i really need. if any one can help me out it would be greatly apreciated.
Old Jan 29, 2003 | 12:40 PM
rioninja's Avatar
Default Re: need advice on putting a ats or jdm 4.7 final drive in a ys1 cable trany (evilxkid)
I'm pretty positive it wont fit.
When installing a type r lsd into a YS1, you need to use an R ring gear because the YS1 ring gear wont fit. So naturally, i would assume the reverse is true.
Just from what i've read, i dont have any hands on experience with YS1s. Yet.
Old Jan 29, 2003 | 03:38 PM
CHEETAH's Avatar
Default Re: need advice on putting a ats or jdm 4.7 final drive in a ys1 cable trany (Rioninja)
you're correct ... plus you don;t need to buy a gsr/ITR ring gear because thats part of the final drive kit ... the differential, however needs to be a GSR or an ITR LSD or aftermarket for GSR/ITR/CTR ... it cannot be for an LS/b16a tranny.
Also, which YS1, hopefully not a USDM LS one because it will be tough to get it to fit, only the USDM GSR YS1 will work or the JDM YS1 (which comes with LSD) will work.
greg
Old Jan 29, 2003 | 04:25 PM
rioninja's Avatar
Default Re: need advice on putting a ats or jdm 4.7 final drive in a ys1 cable trany (CHEETAH)
I understand that, i was just pointing out that the ITR ring gear was indeed different than the YS1 piece. Good info
Old Jan 30, 2003 | 12:42 AM
evilxkid's Avatar
thank's for the help guy's, i should have just e-mailed CHEETAH about this, his name alway's seems to pop up with an answor when it come's to this sort of thing.
thank's
Old Jan 30, 2003 | 12:48 AM
turbohonda's Avatar
greg
Just out of curiosity, why won't the final drive fit in a USDM LS YS1 over a USDM GSR YS1? They both look the same inside to me as far as clearance goes, not considering the ratios.
Old Jan 30, 2003 | 05:42 AM
CHEETAH's Avatar
Default Re: need advice on putting a ats or jdm 4.7 final drive in a ys1 cable trany (turbohonda)
I still can;t figure it out, everything physically fits in just closing the casing is a BITCH .. apparently the offset of a 4.4 or 4.7 final shifts the countergear shaft about 3/10ths " and the bearing doesn;t line up with the top casing ... same **** with the 94+ hydraulic LS trannies ... very weird.
greg
Old Jan 30, 2003 | 03:35 PM
turbohonda's Avatar
greg
I know what you are talking about. So technically it will work in there, just getting the case together is a little harder.
Old Jan 31, 2003 | 05:43 AM
CHEETAH's Avatar
a lot harder ...
greg
Old Feb 1, 2003 | 05:02 PM
smokey2.0's Avatar
honda trannies are very easy to work with, if you stick to one tranny. once you try to hybrid a honda tranny, things change! i my self have put together a hydro ls tranny, with a jdm cable S1 differential with the 4.40 fd ring! it ran just like a gsr except for third and fith gear, where it was a little slower than a gsr(but you couldn't tell unless i told you)! and i had seen a usdm ys1(non gsr), using a a gsr ys1 fd gear ring. that ran pretty good! my next project is to try to fit a type r 2/3/4 gears in a USDM ys1(ls) with a ys1 gsr 4.40 fd! hope it works! if it does, i'll top it off with a quaife lsd!
Lil Krayzee
Sep 2, 2007 08:57 AM
jDAmTeg
May 31, 2007 02:16 PM
Importordomestic
Oct 14, 2005 05:54 AM
turbodsmpower
Sep 23, 2003 08:43 AM
