What offset should i get?
Another battle in the war on "which offset to get for 16" slips on a teg".
I've been told that if the car is not too low, then to get the 40. But, the 45 is supposed to be the "safer" way to go since the 45 is known to clear even a really low car.
The 40 will stick out 5mm more than the 45 adding a little bit of a wider track, but I dont think it would even be noticeable. I think I'll get the 45 since they are almost guaranteed to avoid any rubbing situation, but I'm still trying to decide what to put on my GSR with ITR springs and shocks.
Good luck, and let us know what you decide to go with.
depends on how wide the rims are... slipstream 16s are 7" wide you would want 45mm offset probably.
http://toy4two.home.mindspring.com/offset.html
[Modified by tilt, 8:26 AM 2/10/2003]
