What offset should i get?
Old Jan 29, 2003 | 10:05 AM
Thrillhouse's Avatar
Default What offset should i get?
I have a 99 integra ls lowered on h&r sports, 1.5 in the front and 1.7 in the back. What offset should i get with 16" slips?
Old Jan 29, 2003 | 10:10 AM
fiebru1119's Avatar
Default Re: What offset should i get? (Thrillhouse)
+40
Old Feb 9, 2003 | 11:14 PM
miketegra's Avatar
Default Re: What offset should i get? (fiebru1119)
Another battle in the war on "which offset to get for 16" slips on a teg".
I've been told that if the car is not too low, then to get the 40. But, the 45 is supposed to be the "safer" way to go since the 45 is known to clear even a really low car.
The 40 will stick out 5mm more than the 45 adding a little bit of a wider track, but I dont think it would even be noticeable. I think I'll get the 45 since they are almost guaranteed to avoid any rubbing situation, but I'm still trying to decide what to put on my GSR with ITR springs and shocks.
Good luck, and let us know what you decide to go with.
Old Feb 10, 2003 | 05:25 AM
tilt's Avatar
Default Re: What offset should i get? (miketegra)
depends on how wide the rims are... slipstream 16s are 7" wide you would want 45mm offset probably.
http://toy4two.home.mindspring.com/offset.html
[Modified by tilt, 8:26 AM 2/10/2003]
Old Feb 10, 2003 | 09:27 AM
miketegra's Avatar
Default Re: What offset should i get? (tilt)
bump!
Kennyjai
Apr 26, 2012 05:51 AM
calde-da9
Sep 6, 2007 09:26 PM
Dgilmour
Apr 29, 2006 03:49 PM
MR. ARIZONA
Dec 9, 2002 06:00 PM
00ITR #543
Feb 26, 2002 09:06 AM
