Adjusting clutch cable
Old Jan 29, 2003 | 05:40 AM
muskrat's Avatar
Default Adjusting clutch cable
I've adjusted clutch cables in other vehicles, but never my '89 CRX. The car has an Si tranny and DOHC ZC engine.
I figure the adjustment is on the tranny side, but I've been wrong before, any help would be greatly appreciated.
Old Jan 29, 2003 | 06:09 AM
Superhatch's Avatar
Default Re: Adjusting clutch cable (muskrat)
Yeah...its on the tranny side. There is a little plactic piece on a threaded plastic piece.
Thats the best I could do while I was at work....
That white piece....
(I dont know if thats a civic cable...but you get the idea)
-Jake
[Modified by Superhatch, 9:09 AM 1/29/2003]
Old Jan 29, 2003 | 06:13 AM
muskrat's Avatar
Default Re: Adjusting clutch cable (Superhatch)
Plastic? Really? All the cables I've ever adjusted have been a steel threaded rod with an ajustment nut and a lock nut.
So it's the white piece that I turn right? to tighten the cable I would turn it... ummm... counterclockwise?
Old Jan 29, 2003 | 06:17 AM
Superhatch's Avatar
Actually I think its clockwise to tighten...The actual piece will be black though (usually) and its on the bracket on the very left side of the clutch. I think that bracket also has the tranny ground on it (it might just be near it though). I know the 'nut' is plastic, and im pretty sure the threaded sleeving is too.
-Jake
Old Jan 29, 2003 | 06:19 AM
keithv's Avatar
there is a plastic nut that you turn. you should be able to see it right when you look on the tranny.
to tighten the cable you want to thread the nut in the tighten position, so clockwise.
this is all wishy washy for me though.
Old Jan 29, 2003 | 06:21 AM
muskrat's Avatar
Hmmm, maybe I need more help. With the clutch fully depressed it will not go into gear smoothly, I have to press pretty hard. Not grinding, I think I just need to tighten my clutch cable some... does this sound right?
In the past with other 5 speeds I've had clutch cables streth on me bit, just assuming it's the same thing.
Old Jan 29, 2003 | 06:23 AM
keithv's Avatar
yeah that sounds like a stretched clutch cable.
Old Jan 29, 2003 | 06:25 AM
muskrat's Avatar
Default Re: Adjusting clutch cable (breaka_1_9)
Good, so what you are saying is I should tighten the adjustment clockwise, just wanna make sure.
Old Jan 29, 2003 | 06:34 AM
keithv's Avatar
i am a little bit unsure which way to turn the adjustment nut. if you want to tigthen the cable, you want to get more of the threads "higher" (for lack of a better word). as long as the plastic threads are not reverse threaded, then clockwise should do it.
you will know you are tightening the cable b/c the metal arm that actuates the clutch moves "up".
take a look at it and you'll see what i mean...
Old Jan 29, 2003 | 07:18 AM
PaImportTuner's Avatar
so i been messing around with mine for awhile since swap and been wondering the same thing.. how do you want your clutch tightened.. loose or tight, like how??
when i start my car in the morning i press the clutch of course to start it but once i get off my clutch pedal the car nudges forward alittle(when car idles nothing touched)... when i start my car in the morning the next day, this time i took ebrake off and then started it... the car started moving forward in nuetral on its own.
Old Jan 29, 2003 | 08:31 AM
tpr's Avatar
tpr
Default Re: Adjusting clutch cable (PaImportTuner)
The cable should be adjusted until there is about 3/4 to 1 inch of pedal free play before you "feel" the clutch begining to resist. If you do not have enough free play the clutch can slip. Too much and it may not fully disengage the clutch. Turning the plastic nut clockwise removes free play and counter clock wise to increase it.
[Modified by tpr, 5:32 PM 1/29/2003]
Old Jan 29, 2003 | 08:33 AM
Superhatch's Avatar
Default Re: Adjusting clutch cable (tpr)
Turn it right if you want it tight.
-Jake
Old Jan 29, 2003 | 08:46 AM
Doodoo's Avatar
From what I understand the cable should not have any play at the release arm on the tranny.
My release is very low on the pedal(to the floor). I really hate it. But I don't want to overtighten the cable.
Old Jan 29, 2003 | 09:09 AM
turbo sol's Avatar
Default Re: Adjusting clutch cable (Doodoo)
i read the book on clutch adj. and it siad (i think) 3-4mm of play at the tranny throw out beairng arm. but even then i still seem to need it to eb tighter btu as long as i am really nice when shifting it is fine, I woudl say find a cable honda that shifts good and see how teh tension is on his cable.
Old Jan 29, 2003 | 10:27 AM
DJ_SaNdOz's Avatar
Default Re: Adjusting clutch cable (turbo sol)
righty tighty lefty loosey. lol
Old Jan 29, 2003 | 01:35 PM
Rywire's Avatar
My honda tech teacher tought me, a 1/8 of a inch of play is just right. Ryan
Old Jan 29, 2003 | 01:54 PM
what about my problem?
Old Feb 3, 2003 | 05:27 PM
jdlvl_type_R's Avatar
you might have tighten your clutch too much, and it grabs too much at the top...
[Modified by jdlvl_type_l2, 2:27 AM 2/4/2003]
pauley01
Jan 22, 2007 10:43 AM
The DX Rex
Aug 7, 2006 04:58 PM
bassofbob
Jan 10, 2006 10:20 AM
george34
Sep 23, 2005 02:36 AM
zc911
11
Oct 29, 2002 09:29 AM
