clutch adjustment
clutch adjustment
Is there any way to adjust the engage point of a cable clutch. I have a 0bd0 B16a and the clutch doesn't engage until the pedal is completely out
PHANTOM MENACE
assuming you are running the matching cable tranny, you can adjust the catch point by tightening or loosening the **** at the end of the cable. you'll see it, should be in front of the motor (near where the tranny meets the block) on a lever/arm sticking out of the tranny.
Re: clutch adjustment (bassofbob)
https://honda-tech.com/zerothread?id=960011
go there , it shows a pic .
there is a black cable that comes out of the firewall on the drivers side follow it it goes across the top of your motor down to the transmission on the passenger side you cant miss it . i cant remember for sure which way to turn to get what effect though i think left will engage closer to the floor though , but dont make it so it grabs right off the floor though
