are bigger injectors needed to tune with hondata?
not necessary, but in most cases helpful.
depends on the setup
you maybe could but I think that you will be at a really hight duty cycle
ok.. so is hondata not worth it without bigger than stock injectors?
imo, yes
imo, yes
that saves me alot of money which could have been wasted on hondata and tuning..
imo, yes
ok. thanks.
imo, yes
ok. thanks.
i would recommend the hondata along with 97+ h22a injectors.
the slight increase in flow along with fuel map control will help keep your
duty cycles below 100% which honda likes to do with their stock programs.
Car will run better, make more power, and have less problems
sorry, i misunderstood your question.
i do have a FPR so, can use that with the 240cc injectors to increase flow and just remove fuel with hondata?
thanks.
