b18 oil pan on a b16???
Old Jan 28, 2003 | 09:51 PM
curiousgpnoy's Avatar
Default b18 oil pan on a b16???
i was jsut wondering if you can put a b18 oil pan on a b16 block. my friend busted his oil pan and its so much harder to get a hold of a b16 oil pan...let me know if this will work out...thanx
Old Jan 28, 2003 | 09:54 PM
ace1875's Avatar
Default Re: b18 oil pan on a b16??? (curiousgpnoy)
nope
Old Jan 28, 2003 | 10:09 PM
fowler!'s Avatar
Default Re: b18 oil pan on a b16??? (ace1875)
nope
why not?
I was under the impression that you could put a 1.8 pan on a b16, but not the other way around.
Old Jan 28, 2003 | 10:13 PM
ace1875's Avatar
Default Re: b18 oil pan on a b16??? (fowler)
nope
why not?
well i saw the "moroso" cattalog and for the Oil Pans they got it seprate for the B16 and B18 thats why i gave that answer
Old Jan 28, 2003 | 10:14 PM
Agent#ONE's Avatar
theyre all interchangable, u need the matching pickup however
Old Jan 28, 2003 | 10:17 PM
fowler!'s Avatar
I believe that a b16 pan is too shallow for a 1.8's oil pickup.
Old Jan 28, 2003 | 10:18 PM
Default Re: b18 oil pan on a b16??? (Agent#1)
what do you mean by that??? please explain...pics if you can find some please...thanx
Old Jan 28, 2003 | 10:20 PM
ace1875's Avatar
see the Ls and the GSR have the same oil pan but diff Pickups
Old Jan 28, 2003 | 10:22 PM
well my friend has a b18a1...so what will i have to use to fix it??? ive heard that b18c's would work but i dont even know where to get another b16 one
Old Jan 28, 2003 | 10:24 PM
ace1875's Avatar
b18b1 has a biger displacement then a b18c1
means its bigger then a GSR motor
[Modified by ace1875, 7:28 AM 1/29/2003]
Old Jan 28, 2003 | 10:27 PM
im sorry i meant to say b16a1....my bad
Old Jan 28, 2003 | 10:31 PM
so basically with a b16a1...what are my choices since this motor is orinally from japan???
ace1875's Avatar
Maybe thats why they had diff Oil pan for them
but you have to have a B16 pickup
Old Jan 28, 2003 | 10:33 PM
fowler!'s Avatar
Any b16 motor that was made in the US. (B16A2, B16A3)
I don't want to recommend anything other than those, only for the fact that I'm not *completely* sure that a GSR or LS oil pan will work correctly.
I'm sure they would, but I don't want to be responsible when you're friends motor freezes
Old Jan 28, 2003 | 10:38 PM
where exactly can i find one...besides the dealer because we dont feel like gettin a$$ raped by their prices. i tried to call all the autoparts places around here but they dont carry them and cant even order them. my only other option is the junk yard but that would be kinda hard to find a 99+ civic si motor around. let me know where else i might be able to find one.
Old Jan 28, 2003 | 10:44 PM
fowler!'s Avatar
Try these..
http://thepartstrader.polyactive.net...D=130&PCID=130
http://www.recycler.com/asp/AdDetail...sBAC=562&bSQ=0
Old Jan 29, 2003 | 07:46 AM
any one in the dallas/ft.worth area know where i can get a b16 or b18c oil pan??? we are needing to get my friends car back and running ASAP because its his only means of transportation and he needs it for school and work. if anyone knows where i can find a fairly decent price or have one just laying around please let me know.
you can email me at GQpid@aol.com
[Modified by curiousgpnoy, 4:46 PM 1/29/2003]
Old Jan 29, 2003 | 07:48 AM
RyanR's Avatar
I used a B18C oil pan on my B16 for about 6 months. Never had a problem, never replaced the pickup. Just keep the oil level in check and you won't have any problems. I beat the **** out of the car in the canyons so oil starvation under cornering isn't a problem either.
acydphryck's Avatar
ding ding ding ding!!! give the man a cigar!!! b18 pan will not fit a b16 block einstein....
Old Jan 29, 2003 | 07:49 AM
Phaze2 Mike's Avatar
I have a b16 one laying around i think, but i know the b18a pan is a direct fit onto the b16.
Old Jan 29, 2003 | 07:50 AM
lsvtecracer's Avatar
the b18 oil pan will work on the b16...just use the b18 oil pickup that corresponds with the oil pan....I use it on my car with no problem whatsoever. It's basically the same oil pan, it's just the ls oil pan is a little bit more shallow than the b16 so you have to use the b18 oil pick up.
Old Jan 29, 2003 | 07:57 AM
Agent#ONE's Avatar
Default Re: b18 oil pan on a b16??? (lsvtecracer)
damn people, i DID say, use the coresponding pickup and youd be ok right, why is this thing still going.
Old Jan 29, 2003 | 08:00 AM
RyanR's Avatar
You don't need the pickup, just keep the oil level in check.
DelSol-B18
Sep 21, 2012 04:57 AM
JdelMsolG
Jul 13, 2008 05:26 PM
HighRevn
Jan 31, 2006 06:42 PM
eRACING
Nov 23, 2004 03:46 AM
