Question about tires
Old Jan 28, 2003 | 08:05 PM
kikkoboyie's Avatar
New User
Default Question about tires
If this is a stupid question, I apologize in advance.
Let's say you got a 15X6.5 wheel, and you but a 7 inch wide tire on it.... or a 15X6, and you put a 6.5 inch wide tire on it. What are the advantages and disadvantages, or does it make any difference at all?
I'm asking because at tirerack.com or other tire websites or stores, they say that a 6.5 or a 6 inch wide tire would both work for a 15X6.
Old Jan 29, 2003 | 11:22 AM
Propulsion's Avatar
Default Re: Question about tires (kikkoboyie)
wider = better grip
wider = more weight
Old Jan 29, 2003 | 11:43 AM
evolve's Avatar
Default Re: Question about tires (SilverCIVIC96)
They'll exhibit different sidewall flex, shock load characteristics. Many front-driver touring cars use the same rims all around but a wider tire in front and a narrower tire in the back. This is for various reasons. The narrower rear tires will help neutralize the understeer. The wider tires in front will provide more contact patch, and better deformation angles, plus absorb torque shock through the acceleration curve.
GoLowDrew
Nov 10, 2010 03:24 PM
theeogflip
Sep 11, 2005 08:38 PM
sidious141
Sep 18, 2004 09:23 AM
Bbasso
Dec 5, 2002 12:05 PM
98AcuraGS
Sep 14, 2002 07:06 PM
