Help me with Head gasket Composite removal please
Old Jan 28, 2003 | 07:11 PM
zCivic's Avatar
Default Help me with Head gasket Composite removal please
I have tried everything but the black junk will not come off. Used carb cleaner w/a razor blade, tried a dremel with a polishing wheel, went to a fine wire wheel with a drill and even tried paint stripper. Are there any other removel hint tips you can give me. Thinking of trying air craft stripper, also my friend is gonna let me borrow some aluminum dyes-dies. WTH I really need some help on this one spent over 2 hours trying to clean this and have to get it done tomorrow.
TIA
Old Jan 28, 2003 | 08:31 PM
vhd's Avatar
vhd
Default Re: Help me with Head gasket Composite removal please (zCivic)
try to get most of the big pieces of with a new sharp razor blade. you can use a lapping block and wrapping it with 180grit wet/dry sand paper and use wd-40. just spray it on to the sand paper instead of the deck if the head/block is assembled. use even strokes from one end of the deck to the other. this should remove any gasket material and knicks created fromt he razor blade
D16SiHatch
25
Oct 14, 2007 02:14 AM
vegaskurt
Aug 23, 2005 08:17 AM
1genmud
Sep 20, 2003 06:01 PM
smithbling
16
May 5, 2003 06:06 AM
zCivic
Jan 28, 2003 07:27 PM
