help all mechanics
Old Jan 28, 2003 | 07:06 PM
darkvader's Avatar
Default help all mechanics
i need help guys
i don't know whats wrong
car has skunk 2 cams
port and polished head
pulleys
cam gears
as i was driving and stopped to park, my engine was stalling out and the engine light came up and it died. i started the car up again and soon died. i was able to restart and drove it home 1 mile
-very loud engine clicking noise ( seemed like the valves was bent)
-loud fan noise
-it became hard to steer like the power steering had failed
going to check the code tom
and do a compression test
please help
Old Jan 28, 2003 | 07:13 PM
sslude's Avatar
Default Re: help all mechanics (darkvader)
sounds like you either bent a valve, or something happened to your bearing. who did all the work for you?
Old Jan 28, 2003 | 07:19 PM
vtecfiendsh's Avatar
Default Re: help all mechanics (sslude)
Check all your belts (especially the ones near the power steering) and make sure they are okay... i had a belt go bad once and it make a clicking sound... and the power steering and stuff stopped working... and it overheated
vtecfiendsh 98 SH
Old Jan 28, 2003 | 07:21 PM
prelude1897's Avatar
Start off by seeing what code your engine light is throwing. From there, you can determine whats wrong with your car
Old Jan 28, 2003 | 07:27 PM
darkvader's Avatar
Default Re: help all mechanics (prelude1897)
thanks guys for your fast responses
what is the cheapest way out of this situation buying a stock head
Old Jan 28, 2003 | 07:29 PM
darkvader's Avatar
please help i'm on line often
aim
bugs116
Old Jan 28, 2003 | 07:31 PM
93 VTEC's Avatar
Sounds to me like the cheapest solution for you is to take your car to a qualified technician and let him diagnose the problem. You will be wasting money by 'throwing' parts at your car.
Old Jan 28, 2003 | 07:35 PM
darkvader's Avatar
Default Re: help all mechanics (93VTEC)
eventually i would have to change the valves, work alone will cost alot of money i'm thinking it would cost the same as stock head 500
daylon1650
Mar 7, 2009 01:24 PM
sacredc0w69
Aug 26, 2003 11:07 AM
Ben-VTEC
Apr 10, 2003 05:03 PM
PorscheGT2
Oct 5, 2001 07:13 PM
