J's Racing Engine Dampner Kit
energy suspension motor mount inserts are a way better investment then the engine damper
you need to because if the damper is only on one side it will only dampen one side of the otor causing it slightly twist(common sense tells you that) if you had to they would dampen evenly because the whole motor and trans moves not just the motor
RuffRhyno
Jun 16, 2002 03:05 PM
