89 integra ecu not redlining at 7500
Old Jan 28, 2003 | 05:26 PM
Jockobo's Avatar
Default 89 integra ecu not redlining at 7500
the afc says 6900, i dont really want to go that high but i was wondering why it redlines at 6900 instead of the 7500 that its suppose to be at
Old Jan 28, 2003 | 05:35 PM
USDM 4G VTEC's Avatar
Default Re: 89 integra ecu not redlining at 7500 (Jockobo)
the 88-89 Integra ECU (PG7)
are supposed to redline @ 7200
[Modified by JDM EF9, 9:53 PM 1/28/2003]
Old Jan 28, 2003 | 05:37 PM
Hondasaurs's Avatar
I use the PG7. Its redline is 7200RPM
Old Jan 28, 2003 | 05:45 PM
jasonb's Avatar
Default Re: 89 integra ecu not redlining at 7500 (ZC_CRX)
7200 should be the cutoff
Old Jan 28, 2003 | 05:53 PM
civicdragger818's Avatar
One of my friends had a zc in his 91 si and he had this ecu. When the car was cold it would redline at 6900 but would wrap up to 7800 when it warmed up.
Hondasaurs's Avatar
Ths is what happens to a D series when you rev it past 7800 with stock internals
Old Jan 28, 2003 | 06:04 PM
tvrsir's Avatar
i have a zc ecu if you want it. 100 bucks
Old Jan 28, 2003 | 06:32 PM
boss302's Avatar
Default Re: 89 integra ecu not redlining at 7500 (jasonb)
Old Jan 28, 2003 | 06:42 PM
50shotRex's Avatar
Default Re: 89 integra ecu not redlining at 7500 (boss302)
mines redlined to 7200 also, if u want a pg7 i have one for sale 60shipped, i revved my d16a6 to 8000 and that didnt happend..
Old Jan 28, 2003 | 07:41 PM
Hondasaurs's Avatar
Default Re: 89 integra ecu not redlining at 7500 (50shotRex)
This was reved up to 9000RPM on a chiped ECU. We blew it up on purpose before we did the swap. The cam nearly welded its self to the head.
Old Jan 28, 2003 | 07:51 PM
d15dood's Avatar
<U></U>
yep
Old Jan 28, 2003 | 08:30 PM
Jockobo's Avatar
Default Re: 89 integra ecu not redlining at 7500 (jungle)
is there something wrong with the ecu cause it use to rev up to 7500 when i had camshafts and only when i was at the track. is it stuck on cold mode or something?
Old Jan 28, 2003 | 09:31 PM
ScottEK's Avatar
89 Integra ECU, should be PG7 correct? I believe the actual fuel cutoff on that is at 7800 because I have it on a ZC and I shift at 7200 with no fuel cut at all. The PM6 however, has redlines at 6800 on the tach and fuel cuts around 7200.
D-Boi901
Jan 9, 2007 08:33 PM
junkyardRx
Apr 8, 2004 09:25 PM
SiRWannabe
15
Jun 7, 2002 08:59 AM
crx b16a
Mar 27, 2002 11:07 AM
