help recaro srd install
Old Jan 28, 2003 | 04:22 PM
JDM_Type-R's Avatar
Default help recaro srd install
i was just wondering if anybody knew where to bolt the seat belt buckle to the SRD seat. please let me know. thx.
Old Jan 28, 2003 | 05:13 PM
zer0zer0 TypeR's Avatar
Default Re: help recaro srd install (JDM_Type-R)
what kind of rails do you have? if you have recaro rails there is a spot on the inside of the rear rail where you can use your stock seatbelt buck and bolt, bolts right in.
Old Jan 28, 2003 | 05:14 PM
B2FiNiTY's Avatar
It should be on your rails.
Old Jan 28, 2003 | 05:25 PM
yoshi234's Avatar
I shoot brides
Default Re: help recaro srd install (B2FiNiTY)
you're an expert now
Old Jan 28, 2003 | 05:29 PM
B2FiNiTY's Avatar
Default Re: help recaro srd install (yoshi234)
Ahhh...I will always remember that day. Thanks again Yoshi.
[Modified by B2FiNiTY, 6:30 PM 1/28/2003]
Old Jan 28, 2003 | 05:41 PM
CWESTINAP1's Avatar
seat belt buckles attatch to the brackets.
Old Jan 28, 2003 | 07:20 PM
JDM_Type-R's Avatar
Default Re: help recaro srd install (CWESTINDC2)
k thx guys..one more question..what do i do with this thing...
http://www.imagestation.com/mypictur...m%20pics%20034
any info appreciated. thx guys.
Old Jan 28, 2003 | 07:23 PM
itr-j's Avatar
here is the pic so you dont' have to click the link
Old Jan 28, 2003 | 07:24 PM
B2FiNiTY's Avatar
Default Re: help recaro srd install (itr-j)
isn't that the peice you pull to move the seat back and forth?
Old Jan 28, 2003 | 07:29 PM
JDM_Type-R's Avatar
yea i think so..but i dunno where to screw it onto or where it goes...
Old Jan 28, 2003 | 07:48 PM
Mugen Mike's Avatar
Insert the link between [ img ] and [ /img]
The adjuster handle doesn't screw in anywhere. There should be a "pin" that sticks out the side of the slider, that goes into the hole at the end of the adjuster and then the adjuster goes into the clips right in front of the "pin".
Adjuster should be on the outsides of the sliders too.
There are triangles on the bottom of the sliders (assuming they are Recaro sliders) that point to the front of the seat. HTH
Old Jan 29, 2003 | 09:00 PM
JDM_Type-R's Avatar
also, does anybody know what size or type of bolt i could get to replace the one i lost for my seat belt buckle? just need that 1 bolt connecting the buckle to the rail. any info appreciated. thx guys.
Old Jan 29, 2003 | 11:57 PM
JDM_Type-R's Avatar
need help by tomorrow..tryin to get that damn thing it..cmon guys!
Old Jan 30, 2003 | 12:07 AM
EK MONEY's Avatar
same location as stock. This is not a difficult task. IF you have an aftermarket rail, you need to fab your own brackets by using a thick peice of metal(kind of a sheet, kindof a bar) and bend it to the location.
Old Jan 30, 2003 | 12:10 AM
JDM_Type-R's Avatar
Default Re: help recaro srd install (Peagreenhatch)
i need to know what type of bolt that thing is...
Old Jan 30, 2003 | 12:21 AM
CWESTINAP1's Avatar
its a standard size bolt, sorry i forgot tho =\ either 13, 14, or 15 =T not sure
islander27
Oct 2, 2004 01:09 PM
integRated109
Aug 29, 2002 11:34 AM
GRM Scott
Nov 7, 2001 01:16 PM
TurboIntegra
Sep 5, 2001 04:58 AM
TurboIntegra
Sep 4, 2001 10:47 PM
