Tranny Torque Specs?
Old Jan 28, 2003 | 03:53 PM
420aNT's Avatar
Default Tranny Torque Specs?
I need some torque specs for my 01 GSR. I need the specs for the differential main gear, Tranny Case, Flywheel and pressure plate. Thanks for the help guys. I really need a Helms manual but I need to do this ASAP.
Old Jan 28, 2003 | 04:31 PM
turbohonda's Avatar
Default Re: Tranny Torque Specs? (18gTeg)
The ring gear on the diff is 74ft lbs(left hand threads), 12mm tranny case bolts are 20 ftlbs, Flywheel is 80 ftlbs, and the pressure plate(assuming you use the stock pressure plate bolts) is 18 ftlbs.
Old Jan 28, 2003 | 04:44 PM
420aNT's Avatar
Default Re: Tranny Torque Specs? (turbohonda)
Thanks a ton for your help.
aznej2
Oct 4, 2014 01:35 PM
vtechjunkie
Transmission & Drivetrain
Jul 29, 2009 01:40 PM
aznej2
May 13, 2007 10:33 AM
kaj
Jun 28, 2003 12:04 PM
im_poor
May 7, 2003 09:07 AM
