what happens when my muffler bearing if not working?...
I can't seem to reach my muffler bearing... exhaust is making weird noises for some reason. help.
I checked it but it's still not working? what am I going to do? I have a Tenzo-R 2 1/2" exhaust and I can't do it.
make sure to check your blinker fluid.
Hmmmm...better take another look at that blinker fluid. Blinker fluid...LOL
Hehe...
I think that the donut gasket that goes between the header and the exhaust pipe should count as our muffler bearing. Not only is it a gasket used for sealing, the "bearing" allows the pipe and the header to flex independently.
you'd better be joking.
if not, check the piston return spring...sometimes it sticks and the car sounds like it runs on three cyl.
I had the exact same problem on my N/A boosted D13b what i found was that the non-return two way hyper valve was blocked and stopping the tri-selector gear release bearing from engaging with the dual-flow restrictor microrepeater. So i just plugged the open end of the straight edged curved blow out seal and then re-routed the hyper valve fluid back in towards the transverse side mounted electro-inducer for a freer flowing straight through design
ok first you have to align the dilithium crystals round out the weeble oscelator and then you can remove the flux capacitor. after this the exhaust bearing should be no problem. Oh by the way
IN BEFORE THE LOCK!!!!
http://www.kalecoauto.com/general.htm
if somebody else was looking for the blinker fluid they got that too for $5.99 Each bottle.
http://www.kalecoauto.com/fluids.htm
[Modified by RayRay000, 2:55 AM 1/29/2003]
alleyezonme
Oct 18, 2005 09:06 PM
