Waterpump failures
Old Jan 28, 2003 | 11:08 AM
deleted's Avatar
Default Waterpump failures
What can cause a waterpump to go bad? I have 96 GSR motor with about 30k miles and the waterpump is leaking a little and it has like a knocking noise with it. Engine compression and dyno results are ok. Just wondering what could cause it to go bad since I don't want to be replacing waterpumps often.
Thanks.
Old Jan 28, 2003 | 11:26 AM
b19coupe's Avatar
Default Re: Waterpump failures (deleted)
Waterpumps do fail, but very infrequently. A GSR waterpump that fails at 30,000 miles is atypical. Replace it, and you should not have to worry about it again for 90,000 miles.
Old Jan 28, 2003 | 11:41 AM
Kataku2K3's Avatar
Default Re: Waterpump failures (b19coupe)
You'll notice if the waterpumps bearing has gone out because you'll get a coolant leak from the weap hole in the outer housing... As long as you are not getting a leak from under your T-belt cover I really wouldn't worry about it... If you do happen to change your T-belt soon then it's best to replace the pump anyways no matter what the mileage... You may say it's crazy but whenever I replace a T-belt, maybe even after only 10,000 miles i'll still swap pumps... Just good to know that your parts are good.. Peace
AccordEX1991
Honda Civic (2001 - 2005)
21
Feb 27, 2016 03:27 AM
Mentat Ghola
Jun 1, 2011 08:07 AM
snatch
Dec 7, 2005 12:12 PM
Chunty Butt Kevin
Mar 23, 2005 09:36 PM
RS1995
Feb 24, 2002 05:21 PM
