HELP! car will not start ECU bilnks code 9
I replaced the cap and roter to see if that was the prob and when i went for a spin some thing poped and just deied out and did not start
Cylinder Position Sensor. 3rd the one inside the Diz its a single tooth shaped like a half yin-yang. The Coiling for the sensor proablly has gone, or its not making good contact. Check everything and see if it looks like its unwinding. Also check continuity for the 2 wires in the Diz. Blue/Green and Blue/Yellow it should be between 350-500 Ohms. If out of that spec need to replace snesor or Diz itself
jdmallmotorhatch
Aug 15, 2008 11:03 PM
2poor2tune
Oct 14, 2006 01:19 AM
fast-rex
Jan 27, 2003 04:53 AM
