Best B-series motor mounts?
Does anyone use the original mounts when they swap? I know you need to use a combination of mounts from the motor and the car but do you usually get new ones so that you do not have to replace them later on? Seems like the mounts are pretty expensive.
get the old school weld ins from place racing aNDconvert your car to a 90 - 93 integra . then use 90-93 int mounts with urethane inserts and walla. i have had mine for 4.5 years and not one problem .
What about OEM factory honda SIR mounts? Is there any way to use those in our 4th gen civics?
cut n weld
cut n weld
