kyb agx's matched with 1000 lbs springs?
Old Jan 27, 2003 | 11:30 PM
careawholelot's Avatar
Default kyb agx's matched with 1000 lbs springs?
i'm pretty sure the 1000 lbs springs i have in the rear will blow my kyb agx's, now my ? is do i send them to kyb and have them fix it to run cool with the 1000 lbs springs or do i just find a different shock company that will support the 1000 lbs springs?
Old Jan 27, 2003 | 11:58 PM
sjracer's Avatar
Default Re: kyb agx's matched with 1000 lbs springs? (careawholelot)
can KYB AGX's even be revalved? aren't the top hats welded on? ...well anyways, to answer your question....i think you should get some Koni "yellow's" and have them revalved to handle your 1,000lb/in. spring rated springs...
that'll be your best bet...late
Old Jan 28, 2003 | 04:44 AM
Sonic's Avatar
Default Re: kyb agx's matched with 1000 lbs springs? (sjracer)
Yea, Revalved konis or even remote resevoir motons or Penskes are the only way to go with 1000# springs. KYB's will blow if matched with anythign stiffer than a normal drop spring. Everyone I know who has used KYB's with coilovers (even only 300#) has had them ALL blow.
Old Jan 28, 2003 | 06:23 AM
smokin rubber's Avatar
Default Re: kyb agx's matched with 1000 lbs springs? (Sonic)
Mine havent blown after two years of autocrossing and tracking my accord on 200 and 300# springs.
Why do you need/want 1000# springs,? they will ride like crap.
Old Jan 28, 2003 | 07:15 AM
thirdvector's Avatar
Default Re: kyb agx's matched with 1000 lbs springs? (smokin rubber)
Re-valved Koni's are going to be your most economical solution. Moton remote shocks cost near $1000 apeice. I wouldn't bother even trying to re-valve the AGX.
With 1000lb springs, I hope in-God's-name that you do not plan on using this car on the street! Sounds like fun though, I'm jealous.
Old Jan 28, 2003 | 10:16 AM
xJ.SLOTHx's Avatar
im guessing these 1000lb. springs are only going in the rear anyway...aint no thang...i have friends who use 900~1000lb. springs and they're cars drive just fine. im going to be doing the same soon....
Old Jan 28, 2003 | 10:38 AM
Default Re: kyb agx's matched with 1000 lbs springs? (ian)
yeah right now i have the 1000 lbs springs on my stock shocks and the ride is a little bouncy plus the stock shocks are blown to hell, i think i'm gonna buy the koni yellows for the rear and have them revalve it. thanks guys.
Old Jan 28, 2003 | 10:48 AM
sjracer's Avatar
damn...1,000lb/in springs on stock struts....that's crazy...haha
Old Jan 28, 2003 | 01:21 PM
EpDarks's Avatar
1000 on STOCK shocks!!!
Sweet merciful heaven son. You realize you have hardly ANY performance benifit from that right?
Old Jan 28, 2003 | 05:45 PM
Default Re: kyb agx's matched with 1000 lbs springs? (EpDarks)
what are you talking about, i have no wheel hop at all when i race with these spring rates, and i don't chirp anygears with it on either. just this last weekend i raced my friend with his gsr hatch, and i have d16z6 in a cx i/e are the only mods i have, i blew him off the line so bad and he has a qaiffe(sp?) lsd, he caught up to me right when i shifted into 4th and smote me.
[Modified by careawholelot, 2:47 AM 1/29/2003]
bikerballrEM2
Mar 31, 2008 03:19 PM
lacking vtec
May 27, 2006 07:18 AM
Rancid_949
Suspension & Brakes
Dec 6, 2005 03:41 PM
ayacht
Oct 20, 2002 10:54 PM
sfr4dr
12
Oct 17, 2002 12:52 PM
