F/s: Brand new 2002 Viper 500 ESP alarm system
Here it is:
Viper Alarm:
all this for your low low price of $110 shipped .
seriously, need to get rid of this. paid waay more, but need the money.
thanks
references in signature below
Viper Alarm:
thanks
you guys know you need a new alarm.
protect your cars and the stuff in it.
this is quality stuff here, not some cheapo alarm
for those that have pmed, i have pmed you back
standard features include:
Clone-safe™ 66-bit Super Code-Hopping™
Code-Hopping is an advanced form of vehicle security. This breakthrough technology never sends the same code twice. Code-Hopping was designed to address the growing threat of thieves who use intercepting devices to learn remote transmitting codes so they can disarm vehicle security systems. State-of-the-art security system enhanced by numerous code combinations and Code-Hopping for added peace-of-mind. Code Hopping™ provides state-of-the-art protection against illegal devices called code grabbers, which intercept and retransmit digital codes.
High Security Disarm
Silences siren during alarm cycle without disarming the system.
Soft Chirp®
When arming or disarming, audible confirmation will chirp at 6dB lower than full siren. Now you can have the option of having muted or full chirps. Allows for custom tailoring of chirp sound level.
Failsafe® Starter Kill
The vehicle's starter solenoid will remain connected unless a thief attempts to hot-wire the ignition switch. Failsafe Starter Kill keeps the vehicle where you parked it: No unauthorized user can operate your vehicle once you've armed it, even with your key. The difference between an alarm system and a security system is having this anti-theft feature. Failsafe = peace-of-mind. In some states you can qualify for a discount on your auto insurance rate. Keeps your vehicle where you parkedit. No unauthorized user can operate your vehicle once you've armed it, even with your key.
Active Arming
Gives your customer the option to arm the system from the remote when needed. Personal choice, just like the light switch on the wall, lets you turn it on or off as desired. *See Passive Arming
Passive Arming
When placed in this mode, the security system will arm itself 30 seconds after customer leaves the vehicle. Even if you forget to arm the system, passive arming will protect the vehicle from would-be thieves. This feature can be used in conjunction with power door locks and windows to fully secure the vehicle. *See Active Arming.
Six-Tone Revenger® Siren
It screams, shatters, pierces, blares, raps and zaps! And it has one more big sound: Customer satisfaction. The siren cycles through multiple tones, and by customizing, owners can easily identify their car's siren.
Stinger® Doubleguard® Shock Sensor
The Stinger Doubleguard discriminates between normal, everyday occurrences and potentially harmful intrusions. State-of-the-art sensor technology provides Warn Away output for light impact, or full alarm for stronger impacts. Your system will react accordingly with a standard series of chirps, or a salvo of sirens.
Remote Valet
Where's the Valet switch? Locked away in the glove box! Open the vehicle's door and get in and out of Valet by pressing 1-2-1 on your remote. Remote Valet turns security off but leaves convenience on. You can turn off the system for servicing or valet parking directly from the remote control. Convenience by remote control: No more reaching for a switch installed in the vehicle.
Status LED Light
Serves as an effective visual theft deterrent as well as a diagnostic tool.
Forced Passive Arming
The next level of passive arming. Forced Passive Arming ensures that even if you leave your car door open, the system will arm and bypass that particular zone (door, sensor, switch etc.) after one hour. Passive arming must be selected for this feature to be enabled. Great if you leave your vehicle in a hurry and left it unsecured, Forced Passive Arming ensures you are protected always. Use an existing switch in the vehicle as your hidden override switch. Pick your secret switch, and the number of pulses - no thief will ever find it!
Automatic Engine Disable
AED is a full-time, passive starter kill that works independently of the security system. Thieves can not start your car thanks to AED. Great if you go into a store without arming the vehicle. Automatic Engine Disable takes active arming to the next level!
Nuisance Prevention Circuitry™
Nuisance Prevention Circuitry (NPC) is smart enough to adjust itself to a variety of environmental conditions such as thunder, jackhammers, or airport parking lots. If NPC activates, only the zone that activated three times in 60 minutes is ignored. All other zones remain active, and disarming with the transmitter doesn't reset the NPC; it's only cleared when the is turned on. Best of all, NPC comes back on in an hour if no further problems are detected. No More False Alarms. Nuisance Provention® Circuitry means no more false alarms, whether you're parked at the airport, on a busy street or next to a construction site.
Silent Mode™
Make your system quiet when you want, from your remote. Silent Mode is great for late-night arming and disarming. Simply press Button 2 for one second before arming or disarming, and the confirmation message will be eliminated for that one operation only. Silent Mode™ eliminates all messages and chirps, including the Bypass Notification and Tamper Alert. Patented Silent Mode® lets you silence your arming and disarming chirps, right from your remote. Now you hear it-now you don't! Great for late night arm/disarm.
GPP Nationwide Guaranteed Protection Plan
Refunds your insurance deductible up to $2500 if your vehicle is stolen within one year, even if the vehicle is recovered! Other competing plans do not.
Learn Routine
Up to four individual transmitter codes can be can be programmed via Learn Routine. It makes replacements a breeze. Multiple car security with only one transmitter is easy to create, thanks to Learn Routine. Features and settings are programmed electronically and stored to EEPROM. They are retained in memory when the vehicle's battery is disconnected. Advanced auto security technology.
Panic/Car Locator
Full alarm activates when Button 1 is held down, calling attention to the vehicle. Customer can deter a would-be assailant. This increases personal safety for the vehicle owner/operator. It also can serve as a quick and easy way to find your vehicle in a crowded parking lot. Some systems optional.
Ignition-Controlled Door Locks
Automatically locks doors when ignition is turned on and unlocks them when ignition is turned off. This feature adds safety for vehicle occupants and increases security in threatening situations. It's great if you have kids! Requires Remote Keyless Entry-Power Door Lock interface *See Remote Keyless Entry Automatically locks doors when ignition is turned on and unlocks them when ignition is turned off. Adds safety and increased security. Great for Kids.
Parking Light Flash
When the system is activated, parking lights flash to draw attention to the vehicle. When using the remote: One flash indicates on Two flashes indicates off Three flashes indicates that the system was activated while you were away Confirmation when the system is armed or disarmed makes it easy to use.
Progressive Door Trigger
Prevents users of the vehicle from any undue embarrassment and noise if they open the door without using their remote to disarm the system. It immediately delivers a series of chirps prior to the continuous siren blast. This provides enough time for the user to disarm the system.
Warn Away®
Warn Away reacts with a series of chirps and light flashes* when a light impact is detected. Warn Away delivers more accurate security, providing a response based upon the level of threat. The system will respond appropriately, with proactive protection. Note: Some optional sensors can activate Warn Away (see 508D) *Some Systems Optional Note: Optional voice modules can be used for Warn Away response.
Domelight Supervision
Illuminates the car's interior when disarming, making it easier to look inside the vehicle before getting in. Flashes the domelight during the alarm mode as an added deterrent, providing convenience and peace of mind. Activated automatically by the remote control, domelight supervision provides convenience and piece of mind. Turns on the interior light when disarming, allowing you to look inside the vehicle at night, for peace of mind.
Soft Chirp®
Active Arming
Passive Arming
Remote Valet
Status LED Light
Silent Mode™
Learn Routine
Panic/Car Locator
Parking Light Flash
Warn Away®
please email my roomate....he's very interested but he has a few questions for ya:
pbutynski@mail.csuchico.edu
acuraLSSE95
Audio / Security / Video
Apr 1, 2004 11:58 AM
