Swap tranny fluid?
Old Jan 27, 2003 | 08:50 PM
2k1_ITR_0736's Avatar
Default Swap tranny fluid?
Osaka drains all the fluids? do the take out the tranny fluid? i dunno, just a thought. is the passenger side the side that leaks the fluid when you pull the inner CV's out?
Old Jan 27, 2003 | 11:55 PM
AbaZ's Avatar
Default Re: Swap tranny fluid? (2k1_ITR_0736)
When pulling either axle it will drain a little bit. I dont think they importers drain the trannys completely dry. They usually have alittle bit of fluid in them. Always top them off after installing them.
Use factory Honda MTL or regular 10-30w oil
Jeff
[Modified by AbaZ, 8:55 AM 1/28/2003]
Old Jan 28, 2003 | 06:37 AM
iwhichisme's Avatar
they dont completely drain them, there is usually a little fluid left in the tranny whenthey ship or recieve them. YOu probably will still need to add your usual 2 1/5 quarts.
em12nv
Feb 9, 2008 01:49 PM
shadohconspiracy
13
Nov 4, 2007 08:32 AM
kornerk12
Nov 18, 2005 05:37 AM
AlekSir
Mar 22, 2005 07:20 AM
