What can I do?
Old Jan 27, 2003 | 07:16 PM
civicdragger818's Avatar
Default What can I do?
I have a 88' DX with a 93' b18a in it and I have a friend that does nothing but talk **** because he has a Dodge Neon RT with a 16g Turbo on it. He hates Honda, he dispises the fact that someone actually created such a great company. Anyway he talks **** about how slow my car is when he has never ridden in it. Next tuesday I will be doing a b16a Head swap but I know this isnt quiet the power I need to over take him. I have a S1 JDM b16a tranny and will be soon to have LS-vtec what more do you think I will need. Oh yea and he is running 6psi of boost.
Old Jan 27, 2003 | 07:21 PM
Hondasaurs's Avatar
Default Re: What can I do? (civicdragger818)
If you convert to LS Vtec you willl own him. I had my ZC turbocharged running a 14.2 and I got owned by an LS Vtec (with no major mods) in an 88 CRX DX, he ran a 13.6
Old Jan 28, 2003 | 07:02 AM
iwhichisme's Avatar
i have to agree with zc-crx, he will get owned serioulsy. The differences in weight should considerable, giving you a serious advantage, beside the torque and power you will have from a franky
Old Jan 28, 2003 | 07:09 AM
Agent#ONE's Avatar
Default Re: What can I do? (iwhichisme)
atleast you have a good tranny.
i suggest grabbing yourself a dremmel, and being very carefull, gring out the valve reliefs on the pistons out 2mm, its not much...but it could save your ***...then you can throw some r cams in. and even tune it on stock pistons...
if u can afford it also, get a new itr oil pump, waterpump, timing belt...
and you must use 1.8L head bolts
Old Jan 29, 2003 | 08:29 AM
hondaki33er's Avatar
LS Vtec will kill him. Your car is WAY lighter than he is.
Old Jan 29, 2003 | 08:46 AM
m0nk3y's Avatar
try a thinner headgasket while you're at it?
Old Jan 29, 2003 | 09:34 AM
spettinger's Avatar
Default Re: What can I do? (m0nk3y)
i hear ls vtecs with stock compression put out about 155 to the wheels. there are neons around here that go 14.5 with custom turbo kits. your ls vtec should definitely hold its own again him. keep this in mind: your compression will only be about 10 to 1, so you could definitely hold a 75 shot for 1 ***** out pass.
Old Jan 30, 2003 | 06:26 AM
Anymore oppinions??????
Old Jan 30, 2003 | 06:46 AM
CHRIS 1.8's Avatar
I'd go with a LS/VTEC setup.
Old Jan 30, 2003 | 06:51 AM
crxgurlllll's Avatar
u could get a nos system and just hide it very well(put the bottle under the spare tire cover, run the lines behind everything)
Old Jan 30, 2003 | 06:59 PM
Agent#ONE's Avatar
Default Re: What can I do? (crxgurlllll)
i strongly suggest in an itr intake manifold....sell some blood, but get it, it should put you over the top...
do you have a header?
are you gonna grind the valve reliefs like i suggested, that way yoy dont have to worry about clearance issues.
Reego.
Mar 6, 2005 06:10 PM
n1div
Oct 14, 2004 09:38 AM
Schaz
10
Aug 20, 2004 12:22 AM
civicdragger818
11
Mar 8, 2003 08:15 AM
civicdragger818
26
Nov 20, 2002 11:47 AM
