Rear hatch holding air chucks and cold weather
Old Jan 27, 2003 | 06:37 PM
JPP's Avatar
JPP
Default Rear hatch holding air chucks and cold weather
As a few of you know, we have had a frisky weather front going over the north east in the last few weeks. Last week we dipped to -25 Celsius / -30 Celsius up here in Quebec (that's -stupid cold in farenheit for you metric system challenged) and yesterday I discover that the air chucks used to keep the rear hatch open lost all there holding pressure. Did any of you ever experience this and if so did the holding pressure got back with the warm weather or are the internal seals permently damaged meaning I have to give more money to my friends at Acura.
Thanks
JPP who had to keep the hatch opened with his head while he was trying to load the trunk.
[Modified by JPP, 10:39 PM 1/27/2003]
Old Jan 27, 2003 | 06:41 PM
Dropspeed's Avatar
Default Re: Rear hatch holding air chucks and cold weather (JPP)
AHH Air Chucks=Struts
Mattj
Old Jan 27, 2003 | 06:48 PM
JPP's Avatar
JPP
Default Re: Rear hatch holding air chucks and cold weather (Dropspeed)
Mattj
Would "dampeners" be a more appropriate name?
Old Jan 27, 2003 | 06:58 PM
Padawan's Avatar
Darth ModerVader
I would imagine the extreme cold has just lowered the pressure inside the struts enough to prevent them from holding up the hatch. They should be alright once they warm up, since there should be no reason why they would have "blown" any seals.
Old Jan 27, 2003 | 07:07 PM
magic hat #9's Avatar
Default Re: Rear hatch holding air chucks and cold weather (Padawan)
they will be fine when the weather warms up. the dampeners even have trouble in our toasty 10deg nj weather.
Old Jan 27, 2003 | 09:12 PM
Chris N's Avatar
Default Re: Rear hatch holding air chucks and cold weather (magic hat #9)
I had this same problem in our very recent -10F weather in chicago. The hatch won't stay up for very long before slowly falling back to its original position. I ws also holding it up with my head/neck.
I have noticed that the rubber grommets/stoppers that are attached to the inside of the hatch have gotten so hard and have contracted slightly so that the hatch/trunk makes a good deal of noise when I drive on bumpy roads in this ridiculous cold weather.
Chris - who has a squeaky steering rack and clunky hatch in this ridiculous cold , but good compression numbers (220-215-215-220).
Old Jan 28, 2003 | 12:31 AM
K1R's Avatar
K1R
same thing happened here 2 yrs ago.
im glade had both replaced under warr.
Old Jan 28, 2003 | 07:07 AM
Warren's Avatar
Wrong-Way Wang
Damper.
Warren
Old Jan 28, 2003 | 07:16 AM
GRM Scott's Avatar
25 Year Member
Default Re: Rear hatch holding air chucks and cold weather (Warren)
Damper.
Damper? I damn near killed 'er!
[Modified by Aleph, 11:16 AM 1/28/2003]
Old Jan 28, 2003 | 07:20 AM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Rear hatch holding air chucks and cold weather (Aleph)
Just a reminder to be careful with plastic trim pieces and whatnot in this extreme cold. I learned the hard way how brittle plastic can get in the cold.
Scout's rear window on the soft top = owned
greenjelly
Nov 7, 2017 04:50 PM
SCOTTD08
Oct 2, 2017 04:50 PM
philosofy1
18
Mar 2, 2007 09:52 AM
