where do the extra horses come from in a b18b as opposed to a b18a?
Old Jan 27, 2003 | 03:01 PM
elmalouno's Avatar
Default where do the extra horses come from in a b18b as opposed to a b18a?
yep thats my question...
anyone have links to LS vtec swap info?
thanks
Old Jan 27, 2003 | 03:11 PM
SEA Hag's Avatar
Default Re: where do the extra horses come from in a b18b as opposed to a b18a? (elmalouno)
The extra Hp is rumored to be from better cams in the B18b. I cant remeber the stock comp. ratio of either motor, but that might be another part.
Old Jan 27, 2003 | 03:16 PM
jdmhondageek's Avatar
Default Re: where do the extra horses come from in a b18b as opposed to a b18a? (SEA Hag)
cams are bigger. pistons are the same.
Old Jan 27, 2003 | 03:19 PM
elmalouno's Avatar
Default Re: where do the extra horses come from in a b18b as opposed to a b18a? (Ayanami)
thanks
Old Jan 27, 2003 | 04:13 PM
90da's Avatar
Can you swap the cams, and is it worth it??
Old Jan 27, 2003 | 09:05 PM
Agent#ONE's Avatar
Default Re: where do the extra horses come from in a b18b as opposed to a b18a? (90ef)
cams and intake manifold
Old Jan 27, 2003 | 09:16 PM
Speed PHreak's Avatar
Default Re: where do the extra horses come from in a b18b as opposed to a b18a? (Agent#1)
Yup, exhaust mani in the newer engines also flow slightly better. The ECU's in the newer car's have better tuning also, results in better mpg and a few more ponies. I swapped 93 cams into my 91 engine and could tell a slight difference.
The specs on the 90-91 model 'teg are 130hp/121tq(B18A), the 92-93 is 140hp/127tq(B18A), and the 94+ is 142hp/127tq. My Haynes manual notes differences in the specs on the cams between those models, mostly in the lift.
[Modified by Speed PHreak, 1:20 AM 1/28/2003]
Old Jan 28, 2003 | 07:36 PM
StorminMatt's Avatar
Default Re: where do the extra horses come from in a b18b as opposed to a b18a? (Speed PHreak)
The difference is in the cams, intake manifold (bigger runners and plenum), throttle body (2mm bigger), head (bigger ports), and ECU (tuned to take advantage of all these improvements).
Old Jan 28, 2003 | 09:47 PM
BLOWNEF9's Avatar
intake mani is a huge factor. cams not really
Old Jan 28, 2003 | 09:57 PM
V3locity's Avatar
Default Re: where do the extra horses come from in a b18b as opposed to a b18a? (StorminMatt)
Stormin is right, its really a combination of all these things. There are alot of small differences between them.
iheartjayDem
Nov 10, 2008 08:20 AM
dmpd_ef
Dec 5, 2007 02:58 PM
Rapterboy0269
Oct 15, 2007 11:29 PM
96tegls2dr
Jul 13, 2006 03:30 PM
. L i z
Mar 13, 2006 08:55 AM
