which replacement altenator belt for jdm b16a?
Old Jan 27, 2003 | 02:20 PM
EF-9SiR's Avatar
Default which replacement altenator belt for jdm b16a?
just as the topic asks. I heard usm b18 and b16 work, but i'd just like to confirm. thanx. and changing the belt, can it be done on your own or best to bring it to a shop and have it done?
Old Jan 27, 2003 | 02:49 PM
Malgerus's Avatar
Default Re: which replacement altenator belt for jdm b16a? (EF-9SiR)
so easy to do by yourself... just pull off the belt and compare it ones on the shelf at the autoparts store, then keep the part #
Old Jan 27, 2003 | 03:09 PM
Redline130's Avatar
I used a Del Sol vtec belt.
Old Jan 27, 2003 | 03:28 PM
EF-9SiR's Avatar
Default Re: which replacement altenator belt for jdm b16a? (cyber13)
thanx for the info guys. is oem best? and its a diy, right? oh, and what year del sol vtec?
[Modified by EF-9SiR, 1:28 AM 1/28/2003]
Old Jan 27, 2003 | 05:27 PM
Redline130's Avatar
OEM is the best. I used a 94 belt, but I'm sure any 94-97 or 99-00 Si alternator belt will work.
http://www.hondaautomotiveparts.com
Old Jan 27, 2003 | 06:39 PM
iwhichisme's Avatar
90-93 ls integra, or gsr. Either one works
Old Jan 27, 2003 | 07:01 PM
EF-9SiR's Avatar
Default Re: which replacement altenator belt for jdm b16a? (iwhichisme)
i was looking at parts numbers for the belts....93 gsr and 95 del sol vtec are the same....the 2000 si is close. but then i looked at length. the 2000 si is an inch shorter. is that a big difference?
[Modified by EF-9SiR, 4:06 AM 1/28/2003]
Old Jan 27, 2003 | 07:02 PM
SC0TT's Avatar
I used a 99-00 Civic Si belt.
Old Jan 27, 2003 | 08:37 PM
kanzenr91si's Avatar
Default Re: which replacement altenator belt for jdm b16a? (cr-tegra)
use the 99-00 si its shorter so it will help with alternator clearance.
junior_tm
Apr 8, 2009 08:37 PM
Bonestock98GS
Sep 2, 2008 09:21 PM
HONDA_F1
May 31, 2005 09:05 AM
94 civic all mtr
Dec 16, 2003 10:37 AM
SC0TT
Sep 22, 2002 10:31 AM
