Driving with a lightened flywheel
Old Jan 27, 2003 | 12:53 PM
3700 Vtec's Avatar
Default Driving with a lightened flywheel
I've heard that having a light weight flywheel essentially eliminates normal driveability (depending on how light the flywheel is compaired to stock) because the motor dies too easily.
Of those of you out there running light weight flywheels how is ride?
Old Jan 27, 2003 | 12:55 PM
urbanlegend21's Avatar
New User
Default Re: Driving with a lightened flywheel (3700 Vtec)
takes a little more throttle to manuaveer in traffic, but you do not want to really run a light "racing" type flywheel for a daily driver
Old Jan 27, 2003 | 01:25 PM
sauceman's Avatar
I have nothing to complain, I am all satisfied with my 10lbs, and I drive a lot, about 50,000 miles per year.
Old Jan 27, 2003 | 01:30 PM
tilt's Avatar
Whoever said that probably never had a lightweight flywheel. 7.5lbs here and it is very daily drivable.
Old Jan 27, 2003 | 01:58 PM
niedejb's Avatar
Default Re: Driving with a lightened flywheel (tilt)
My engine never died from the lightened flywheel.
I've said from day one this is the best NA mod you can do to the F series.
Old Jan 27, 2003 | 03:07 PM
3700 Vtec's Avatar
Default Re: Driving with a lightened flywheel (niedejb)
Thanks for the responses.
What brands do you guys have?
Old Jan 27, 2003 | 05:09 PM
sauceman's Avatar
Amen
Old Jan 27, 2003 | 05:38 PM
niedejb's Avatar
Unorthodox racing. Pricey ($490), but there were no clutchmasters or fidanza to my knowledge when I did it.
I got it and the clutch installed for $350 @ a Honda dealer before I had my garage.
Old Jan 27, 2003 | 05:41 PM
poid's Avatar
Damn right, first thing i noticed about the F engine was how it seemed to need a lightened flywheel.
I suppose i better get one...
Old Jan 27, 2003 | 07:06 PM
Nick M's Avatar
Default Re: Driving with a lightened flywheel (poid)
On my H I have an Aasco 8lb flywheel, no PS or AC and a straight intake with a battery relocation to the trunk. The throttle response and the revs are great.
Old Jan 28, 2003 | 07:43 AM
Brandon's Avatar
Life is Suffering
Default Re: Driving with a lightened flywheel (Nick M)
Accords have such heavy cranks that they barely need much of a flywheel. However, you don't want to go too low, or else the engine may have problems with stalling out when driving over a hill. But that was a problem I had with a 924, not an Accord.
Old Jan 28, 2003 | 09:38 AM
YeuEmMaiMai's Avatar
having a lighter flywheel also causes a very rough idle as the weight of the flywheel is not enough to help smooth out the engine firing.
it does have it's advantage though engine spools up quicker as there is less mass to move in the flywheel
Old Jan 28, 2003 | 12:50 PM
Nite's Avatar
Default Re: Driving with a lightened flywheel (YeuEmMaiMai)
What do you guys think of gettin the flywheel machined so its lighter? Ive heard people do it but im not sure how reliable it is so people seem to think it is while others believe it isnt.
Old Jan 28, 2003 | 01:43 PM
niedejb's Avatar
Default Re: Driving with a lightened flywheel (Nite)
Youd be better off with aluminum.
Youll never get to 10lbs by machining the stock one.
Mine is aluminum and ran it with the ACT extreme pressure plate/street disc and the turbo....no issues.
Old Jan 28, 2003 | 02:02 PM
sauceman's Avatar
I'm starting to think about the possibility of machining my UR Flywheel to lighten another 2-3lbs, and re-balancing it. Wonder if I'd be taking it too far, though... ( )
leondx
Honda CR-V & Element
Mar 3, 2013 05:08 AM
D16SohcVtec
Jul 22, 2008 06:39 PM
Cyrio
62
Aug 14, 2006 05:11 AM
EJ8 GSR-T
Jan 30, 2006 10:34 AM
Mr. 1582
17
Sep 21, 2003 06:21 PM
