Which radiator: FLUIDYNE or KOYO to replace the Stock radiator?
Old Jan 27, 2003 | 12:15 PM
Spyderwebab's Avatar
Default Which radiator: FLUIDYNE or KOYO to replace the Stock radiator?
I just got my rebuilt engine back and my stock Radiator is so bad that it is going through a full resivor tank a day. I need to know which radiator is better for street racing with Toda b's and ~12:1 compression.
I'm leaning towards FLUIDYNE but radiators.com only sells KOYO which is more expensive and it may be better.
Bonus: I'd like to be able to keep the stock fans, and I'm NOT running AC.
For both Radiator specs here:
http://www.absoluteradiator.com/Prod...e.asp?idProd=3
[Modified by Spyderwebab, 4:23 PM 1/27/2003]
Old Jan 27, 2003 | 12:17 PM
Dave-ROR's Avatar
Default Re: Which radiator: FLUIDYNE or KOYO to replace the Stock radiator? (Spyderwebab)
you cracked the stock radiator?
I haven't replaced a DC2 radiator with a Fluidyne or a Koyo but for RX7's I like the Koyo more.. not that this helps you. IMO either will be fine, was just curious how you cracked the stock unit.
Old Jan 27, 2003 | 12:19 PM
B18CXr's Avatar
stock unit is more than fine
Old Jan 27, 2003 | 12:20 PM
Default Re: Which radiator: FLUIDYNE or KOYO to replace the Stock radiator? (FyrStarter)
Yes its cracked, the GSR radiators suck ***, many of our radiators go bad at the seals....
Old Jan 27, 2003 | 12:21 PM
B2FiNiTY's Avatar
I like Koyo. But both are nice.
Old Jan 27, 2003 | 12:28 PM
Eva01's Avatar
Yup, everyone has the same problem. I have a fluidyne but either is a good replacement. The fluidyne needs a thinner fan for the AC which runs about 70$. Not sure about the Koyo but pretty sure they require also require a thinner AC condenser fan.
Old Jan 27, 2003 | 12:32 PM
Default Re: Which radiator: FLUIDYNE or KOYO to replace the Stock radiator? (Eva01)
Well I have a CTR crank pully so I don't have to worry about the AC fans, I'm just wondering which I should go with: the Koyo is $340, 53mm thick and the Fluidyne is $320, 38mm thick. I think I'd be fine with either one I'm just wondering if someone here has some hand on experience with either one which would put one over the other.
[Modified by Spyderwebab, 4:32 PM 1/27/2003]
Old Jan 27, 2003 | 12:33 PM
B2FiNiTY's Avatar
I have seen both and the koyo is higher quality.
Old Jan 27, 2003 | 12:45 PM
00MRSi's Avatar
Default Re: Which radiator: FLUIDYNE or KOYO to replace the Stock radiator? (B2FiNiTY)
You should be fine with either. Anyone use C&R radiators?? They look nice too..
Old Jan 27, 2003 | 12:52 PM
Just ordered the Acura Integra Koyo All Aluminum Racing Radiator, for $340 + $20 for next day delivery. I'll tell you guys how it goes.
Edit: ordered from http://www.radiator.com
[Modified by Spyderwebab, 4:53 PM 1/27/2003]
Old Jan 27, 2003 | 12:59 PM
vtecvoodoo's Avatar
Future Texas Boy
I have the Koyo in my EK. Very nice.
Old Jan 27, 2003 | 01:31 PM
Track rat's Avatar
Default Re: Which radiator: FLUIDYNE or KOYO to replace the Stock radiator? (vtecvoodoo)
Does anyone know if a Fluidyne or Koyo is a weight savings compared to stock? Or, does it possibly ADD weight because of higher fluid capacity?
Old Jan 27, 2003 | 05:12 PM
JDMITR222's Avatar
Old Jan 27, 2003 | 05:37 PM
baonest1's Avatar
Default Re: Which radiator: FLUIDYNE or KOYO to replace the Stock radiator? (JDMITR222)
anyone know anything about C&R. they have a best buy for $380 shipped with cap and fans. i need a new rad also for my new motor.
thanx.
Old Jan 27, 2003 | 06:35 PM
newspeedR's Avatar
Default Re: Which radiator: FLUIDYNE or KOYO to replace the Stock radiator? (baonest)
thanx.
C&R actually has a thicker core then the Fluidyne... it is top notch...
for the price, you cant get better and beat the performance...
Old Jan 27, 2003 | 06:37 PM
Dropspeed's Avatar
Default Re: Which radiator: FLUIDYNE or KOYO to replace the Stock radiator? (newspeedR)
We use C&R for all of our project cars, Great quality, good fitment, no problems
Mattj
Old Jan 27, 2003 | 07:00 PM
baonest1's Avatar
Default Re: Which radiator: FLUIDYNE or KOYO to replace the Stock radiator? (Dropspeed)
hey thanx for the replies guys.
Old Jan 27, 2003 | 07:58 PM
97 TYPE-R 312's Avatar
I run a KOYO. It's 55 mm thick, 5 mm thicker than a Fluidyne. Not sure against a C&R though. As for quality, the KOYO is nicer than the Fluidyne side by side comparo. Stock fan will work with the Fluidyne, NOT the KOYO though.
Thanks,
Victor
Old Jan 28, 2003 | 03:41 AM
NunRacer's Avatar
How much street racing do you that you need a better radiator? If you went to the track then I would understand.
Old Jan 28, 2003 | 04:16 AM
JohnnyK's Avatar
thanx.
Old Jan 28, 2003 | 04:17 AM
migs's Avatar
Default Re: Which radiator: FLUIDYNE or KOYO to replace the Stock radiator? (NunRacer)
Yup, Groupbuycenter.com is having a groupbuy on C&R radiators for $380 shipped.
It includes the drain plug, cap, AND thin fan. Ill be ordering mine soon.
Old Jan 28, 2003 | 06:27 AM
Honda318dx's Avatar
Default Re: Which radiator: FLUIDYNE or KOYO to replace the Stock radiator? (B18CXr)
DUH! But it doesn't look kool..
Old Jan 28, 2003 | 09:56 AM
The GSR radiators have a tendency to go bad at the seals, in my case it is so bad it leaks an entire resivor/overflow coolant tank a day.
Also Someone mentioned on this thread that you can't use the stock fans w/ the Koyo radiator, Why can't you? Because you don't have enough room? Well I'm not running A/C and I asked the guy at http://www.radiator.com if stock fans worked and he said Yes. I'm confused now, why won't they work?
GettaluvR
Mar 26, 2003 03:29 PM
dc2g
Mar 10, 2003 10:40 PM
Spyderwebab
Jan 27, 2003 01:43 PM
