Went to the track with the untuned cams.....
Old Jan 27, 2003 | 11:27 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Went to the track with the untuned cams.....
As you guys know I only put down 173whp with my skunk II stage ones. Well I went to the track Sat just to see what it would do. I wasn't able to hook up and could only pull a 2.2 60' and was spinning a tad in second gear but I managed a best of 13.9@100.8mph. That is my fastest trap so far. That makes me wonder what I'm gonna trap if I can tune 10 more whp out of these things.
< goal is to trap 102mph with full interior.
Old Jan 27, 2003 | 11:36 AM
SurferX's Avatar
Default Re: Went to the track with the untuned cams..... (ActiveAero)
So untuned they aren't really doing anything yet then?
I wish I could go to your track haha. Man you pull some good times there, everyone gets slow times messed up trap speeds at my track.
[Modified by SurferX, 12:38 PM 1/27/2003]
Old Jan 27, 2003 | 11:50 AM
Dave-ROR's Avatar
Default Re: Went to the track with the untuned cams..... (SurferX)
Well with a 2.2 60foot he should get better times if he does his normal 60 foot times..
Old Jan 27, 2003 | 12:04 PM
Misfit's Avatar
Default Re: Went to the track with the untuned cams..... (FyrStarter)
i just dynoed untuned at 183.. so i wonder what i will be running now. Need to get to the track.
Old Jan 27, 2003 | 12:05 PM
sgT's Avatar
sgT
Remember, 60' go down, trap goes down with it
Old Jan 27, 2003 | 12:07 PM
RTW DC2R's Avatar
Default Re: Went to the track with the untuned cams..... (MISFIT)
Last year before my buildup, I dynoed at 178 and only ran 14.7 with a 2.3 60...damn i suck.
nice run
Old Jan 27, 2003 | 12:14 PM
Dave-ROR's Avatar
Default Re: Went to the track with the untuned cams..... (sgT)
I didn't say he'd trap at higher MPH, just that with his normal 60 foot times he'd probably beat his 13.7 run with the stock cams.
Old Jan 27, 2003 | 12:19 PM
sgT's Avatar
sgT
That was meant more for the benefit of mr "i want to trap 102" than you dave
Old Jan 27, 2003 | 12:22 PM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
I dyno'd @ 185 and ran a 14.3 with a 2.4-2.6 60ft time. Needless to say I was pissed.
Old Jan 27, 2003 | 12:24 PM
Dave-ROR's Avatar
damn n00bs learn to reply correctly! lol
-Dave, who will probably lose % for this post hehe
Old Jan 27, 2003 | 12:26 PM
AssPenny's Avatar
Why would anybody run there car to the fullest with out tuning? Don't care how long your motor lasts or something?
Old Jan 27, 2003 | 12:27 PM
Dave-ROR's Avatar
Default Re: Went to the track with the untuned cams..... (AssPenny)
what's tuning?
-Dave, who sees no problem strapping a T04 to a B18C and just running it at 20psi lol
Old Jan 28, 2003 | 12:59 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
When I said untuned I meant not tuned to the fullest potential. I hit the dyno but all I had to mess with was cam gears.
Oh and my trap speeds usually go up with a better 60' because I launch really high. Its not like I get better 60's because I'm bogging the car down. If I can pull a 2.0-2.1 60' by launching at 7,000rpms thats just more time for me to be accelerating instead of spinning. Generally speaking though you are correct.
Old Jan 28, 2003 | 01:24 PM
SergEK's Avatar
I kinda agree with that....some of my best traps came with some of my best 60's. I think lauching harder allows you to use up more of the track for acheiving a higher trap instead of using those precious feet for doing a nice 60ft peel.
Good luck Aero
Old Jan 28, 2003 | 01:27 PM
Johnny Tran's Avatar
i agree....
if it blows, who cares, its a honduh. btw im still laughing about that assclown in Fl that put down an Asscrushing pisspoor 247 down in his hype arrr on b00st. LOL
Old Jan 28, 2003 | 02:36 PM
icefire069's Avatar
Default Re: Went to the track with the untuned cams..... (Johnny Tran)
2.2 60 ft 14.3 stock 167@ wheel
2001 itr py
2001 S2000 silver <sold> 14.00 @99 stock =
2003 smg m3
Old Jan 28, 2003 | 04:29 PM
Buckshot's Avatar
Default Re: Went to the track with the untuned cams..... (icefire069)
why is your car so damn quick..you gotta be some sorta crazy shifter
Old Jan 28, 2003 | 04:54 PM
Hooch'n's Avatar
Default Re: Went to the track with the untuned cams..... (Buckshot)
tune your car!!!!!!!
Old Jan 28, 2003 | 05:11 PM
2001TypeR's Avatar
Well remember you said that it spins the tires like crazy now down low even, you have more power and its gonna be hard to put down, also for some reason your dyno showed you make crazy low to mid end power and took your peak whp and torque down by a good amount, this will make it harder to launch...but you did tune for midrange so you got it, lol
Old Jan 29, 2003 | 03:09 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Only PY Type-R's come with "Mad Skillz" as standard equipment.
Old Jan 29, 2003 | 05:13 AM
sneakychaos's Avatar
What psi are you running up front on what kinda tire?
Old Jan 29, 2003 | 09:40 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Default Re: Went to the track with the untuned cams..... (sneakychaos)
I run about 25psi or so in my Potenza SO-3's.
Old Jan 29, 2003 | 11:49 AM
2001TypeR's Avatar
Try like 20 psi or around there, should be better....damn man you still ran a high 13 with like a stock 2.2 60ft....get it back to your average 2.0-2.1 and your a mid 13 untuned
Old Jan 30, 2003 | 07:17 AM
SergEK's Avatar
I think my ITR motor came out of a 00 PY then
14.0@97.7 at 2800+ft <------- 12 deg timing, I/h = 163 whp, drag radials, Si ECU
Old Feb 4, 2003 | 05:26 AM
june's Avatar
Default Re: Went to the track with the untuned cams..... (SergEK)
What was your 60ft? My best so far is 14.15@98mph with a 2.2 60ft
