Steering wheel Play
Old Jan 27, 2003 | 10:48 AM
Toptul_Honda's Avatar
New User
Default Steering wheel Play
I have steering wheel play. Its pretty bad on the highway. Especially when i am turning the wheel clockwise (turning right)
what can it be?
- Steering gearbox (hoping its not cause thats a bitch and expensive part too)
- tie rod ends?
- Anything else?
[Modified by G2-Rex, 1:55 PM 1/27/2003]
Old Jan 27, 2003 | 12:45 PM
Ef Whore's Avatar
Default Re: Steering wheel Play (G2-Rex)
actually turning left is counterclockwise.
Old Jan 27, 2003 | 01:03 PM
charjacq's Avatar
New User
Check the bolt underneath the 'H' sign right in the middle of the steering wheel. It could be as stupid as that.
If that's not it, it is either the rack and pinion (worst case) or the steering rods ball joints (not so bad).
If you don't know what I'm talking about, have it checked. Steering is an important issue. Don't try to save a buck there!
Old Jan 27, 2003 | 03:01 PM
New User
Default Re: Steering wheel Play (charjacq)
what are the chances that its rack an pinion?
Old Jan 27, 2003 | 04:14 PM
charjacq's Avatar
New User
Start by checking the steering wheel bolt, then the steering ball joints. If they are fine, chances are it is the rack and pinion. That would suck, because it's expensive.
Old Jan 27, 2003 | 05:44 PM
Snapshift's Avatar
Sh-t dude it's sounds like a looose tie rod. If ya lose one more bolt you will have no control of your car. It's an easy fix. Just hoist the car and remove the existing anchor, find a matching one, replace the missing bolt and wrench em both down. It's located just on the oppisite side of your foot drivers foot pannel.And very easy to do.
Old Jan 27, 2003 | 05:46 PM
New User
Default Re: Steering wheel Play (Snapshift)
so what do i have to replace? anything? any pics or diagrams to help me out?
Old Jan 27, 2003 | 06:04 PM
JaiDM's Avatar
not to worry you. but it sounds like the rack, i have went through one rack already, and now my 2nd one is starting to go. haha! and my steering wheel would have play in it too. also the alment is a little off. and when you shack you steering wheel back and forth you can hear a little knocking sound.
Old Jan 27, 2003 | 09:03 PM
New User
Default Re: Steering wheel Play (JaiDM)
how much can i get a rack for? and from which car will it work on my CRX
Old Jan 27, 2003 | 09:19 PM
Kato7997's Avatar
could possibly be bushings...
Old Jan 27, 2003 | 09:50 PM
New User
Default Re: Steering wheel Play (Kato7997)
hoping its not the rack. that would be bitchin. best case would be tie rods, and bushins...
Old Jan 28, 2003 | 12:43 AM
FRESH's Avatar
Jack the front of your car up.... Then hold the wheel and try and move it left to right, then up and down and feel for play.. Most likely its the tirerod ends as in the ball joints in the tie rod. Myne are fucked.. my wheels shakes about 4mm when i turn at 30mph or above.. i just checked my **** and its the tie rods.. gotta fix them soon.
Old Jan 28, 2003 | 10:14 AM
New User
Default Re: Steering wheel Play (FRESH)
ok well i turned off my car and turned the wheel. there is minor clunking noise (probably from the gears of the steering gears of loose tie rod/ends ill look at it the end of this week and tell u guys
Old Jan 28, 2003 | 11:07 AM
2k2silvertype-s's Avatar
if you want to see if it's your tie rods jack up your car and get your suspension to unload all the way. press in on the top of the tire and if the wheel/tire leans in you got some problems.
Old Jan 28, 2003 | 05:41 PM
New User
Default Re: Steering wheel Play (2k2silvertype-s)
oko sounds good. and if it doesnt? then it must be the steering rack?
Old Jan 28, 2003 | 08:41 PM
New User
well i found out the problem. MY upper ball joints had play (picked up some used arms with good condition ball joints- looked like they were replaced) and my tie rod ends werent exactly tight (castle nut wasnt fully threaded in after i did my clutch job!!) after i put my new arms in im going to the alignment shop and going to get my gear box tightened to remove the rest of the play!
Thanks ALOT for all your help guys!! Honda-tech has the most helpful guys
MotorMouth93
Jan 17, 2015 03:58 PM
civic4life8045
18
Jun 5, 2013 09:10 AM
huckaboo
Suspension & Brakes
Apr 7, 2009 02:20 PM
nk2k2
12
Oct 19, 2006 05:23 PM
jabroni95gsr
Feb 13, 2003 04:12 AM
