difference between Si front strut bar and the DX front strut bar ??
Old Jan 27, 2003 | 10:26 AM
zcivicz's Avatar
Default difference between Si front strut bar and the DX front strut bar ??
i went to my local accesories store and ordered a ractive front strut bar for my 89 civic dx. the guy asked me what model and i told him they SHOULD all have the same part no. and the guy said no and i took a look and he was right!
so whats the diff between the Si and DX strut bars ???
oh yeah i'd appreciate it if someone replies to this right away cuz i need to tell the guy to just get an Si front strut bar for me cuz i'm converting to mpfi and i'm thinking the int manifold might be in the way of the strut bar.
[Modified by zcivicz, 7:27 PM 1/27/2003]
Old Jan 27, 2003 | 10:42 AM
zCivic's Avatar
Default Re: difference between Si front strut bar and the DX front strut bar ?? (zcivicz)
Well I know that the SI bar on a DX kinda pushes the DPFI cover down quite a bit. The DX will hump a little higher. Should work with either DPFI or MPFI. Are you sure was looking at 88-91 DX never seen one really seen 92+
Old Jan 27, 2003 | 10:44 AM
zcivicz's Avatar
Default Re: difference between Si front strut bar and the DX front strut bar ?? (zCivic)
oh ok so no need to change my order since all its going to do is give me slightly more room between the intake manifold and the strut bar. nothing wrong with that as long as it doesn't hit the hood.......right ??!
Old Jan 27, 2003 | 10:48 AM
zCivic's Avatar
shouldn't be any problems with that. You can accually use front bar from 90-00 tegs or 88-00 civic as long as they mount to the upper strut post and not below them like CTR or ITR bars
[Modified by zCivic, 2:49 PM 1/27/2003]
[Modified by zCivic, 3:00 PM 1/27/2003]
Old Jan 27, 2003 | 11:25 AM
4drEF's Avatar
Keyboard Humorist
The DPFI bar is not straight across. It routes in front of (not above) the DPFI black box that is on top of the TB.
On the MPFI models, the intake manifold is in that area and the TB mounts to the side of it (not on top like the DPFI) so they run the bar straight across because they have no clearance issues.
Old Jan 27, 2003 | 01:07 PM
zcivicz's Avatar
Default Re: difference between Si front strut bar and the DX front strut bar ?? (4drEF)
so should i tell them to order an Si strut bar or a DX since i'm converting to mpfi when spring arrives.
Old Jan 27, 2003 | 01:30 PM
TheBestCRX's Avatar
i'd get the Si unless you want to put the strut bar on while you have DPFI.
Old Jan 27, 2003 | 02:39 PM
zcivicz's Avatar
Default Re: difference between Si front strut bar and the DX front strut bar ?? (88CRXSiB17)
well is it better to have the strut bar just straight across ?? does it really matter whether its straight or not i mean they're designed to perform the same...right?
i do want to put it on right away
Old Jan 27, 2003 | 03:20 PM
shorti's Avatar
i had this same problem....if you order an si strut bar and you have a dx with DPFI then you're fuked....the strut bar will hit the DPFI......
the dx strut bar goes behind the DPFI almost touching the firewall
Old Jan 27, 2003 | 03:30 PM
4drEF's Avatar
Keyboard Humorist
Default Re: difference between Si front strut bar and the DX front strut bar ?? (shorti)
Did you put it on backwards? I have only seen them on the other way where they go in front of the DPFI.
Old Jan 27, 2003 | 03:33 PM
shorti's Avatar
it only went one way
want a pic?
Old Jan 27, 2003 | 03:45 PM
zcivicz's Avatar
yeah let's see a pic! i've never seen a DX strut bar before only the Si.
is that dpfi box in the way so if you were to try and put on an Si strut bar that you wouldn't to bolt it down on the strut towers ?? is that how bad it is.
Old Jan 27, 2003 | 05:55 PM
shorti's Avatar
sorry for the shitty pics.....
it's cold and my hands were shakey
and don't mind my ghetto intake
Old Jan 27, 2003 | 06:07 PM
91SIvic's Avatar
i got my tenzo from a buddy of mine that had it on a 90 integra gsr.. fit perfect...
Old Jan 27, 2003 | 06:22 PM
EG8R's Avatar
Solid machinery there!!! Go Buddie Go!!! So whens the MPFI going on???
Old Jan 27, 2003 | 06:26 PM
shorti's Avatar
Default Re: difference between Si front strut bar and the DX front strut bar ?? (mr. skelly)
saving for a b16a.....
i just wish i had monies now
Old Jan 27, 2003 | 06:57 PM
jdmjim's Avatar
whats up man? i agree with ya.
seanewing
Jan 12, 2011 02:30 PM
Wazup
May 23, 2004 11:31 AM
black-hatch
Apr 9, 2003 10:23 PM
Ty.
Mar 5, 2003 12:12 AM
Turbo Powa
18
Oct 2, 2002 06:03 PM
