Need help aligning my headlights...
Old Jan 27, 2003 | 10:01 AM
skafia's Avatar
25 Year Member
Default Need help aligning my headlights...
My headlights are so screwed up right now. They're pointing in different directions. I'm trying to align them but I messed with the level and I think I threw the whole system off. Does anyone know how to resynchronize the headlights with the level?
Sorry if this thread sounds a little confusing.
Old Jan 27, 2003 | 10:13 AM
ZygSpeed's Avatar
Default Re: Need help aligning my headlights... (skafia)
HTH
https://honda-tech.com/zerothread?id=189423
Old Jan 27, 2003 | 10:19 AM
AssPenny's Avatar
Default Re: Need help aligning my headlights... (zygspeed)
Also the scan from the helms is in this thread
https://honda-tech.com/zerothread?id=354140
Craig - Who really should adjust his due to blinding the person infront of him
[Modified by AssPenny, 2:19 PM 1/27/2003]
Old Jan 27, 2003 | 10:22 AM
Big Phat R's Avatar
when I lowered my car - it rendered the leveling apparatus on the back of the lamp housing useless. I used a wall for initial alignment and then went out on a dark road to do some further adjustments. You can have the right lamp set a little higher to aid forward vision without blinding oncoming drivers.
the end result was both headlights pointing a lot higher than stock and the bubbles in the levels stuffed in the "+" end.
four-eyez
Apr 6, 2005 02:01 PM
1fastvtec
Feb 19, 2005 06:57 PM
GregblkEx04
Feb 12, 2005 09:28 AM
ravinR68
Feb 24, 2004 10:59 PM
pwr_crx
Sep 27, 2003 08:04 PM
