???88 HF, Rear sway bar and disc brakes???
Old Jan 27, 2003 | 09:17 AM
Timmah!!'s Avatar
Default ???88 HF, Rear sway bar and disc brakes???
I spent a little time researching rear break swaps in the archives, but most of what I could find was on DXs or Hatches. I know that the 88 HF had a the similar rear suspension to the ITR, and also has no rear swaybar.
I would like to know what is involved in installing rear discs (yes I know the breaking power gains are minimal) and installing a rear swaybar. I m am not sure if the procedure is the same for the 88 HF, as it is for the later model CRXs.
[Modified by azroth, 3:27 PM 1/27/2003]
Old Jan 27, 2003 | 11:17 AM
4potnick's Avatar
Default Re: ???88 HF, Rear sway bar and disc brakes??? (azroth)
I have a friend with a 88hf that needs to know this info, anyone.
Old Jan 27, 2003 | 11:27 AM
Timmah!!'s Avatar
Default Re: ???88 HF, Rear sway bar and disc brakes??? (4potnick)
Old Jan 27, 2003 | 04:48 PM
Timmah!!'s Avatar
TTT
Old Jan 27, 2003 | 08:40 PM
TheBestCRX's Avatar
i'm not totally sure but i think it is only the 88 CRX Si with the different rear suspension. as for the rear discs i wouldn't worry about em.
and for the rear sway bar, i don't think the HF's had control arms with holes to mount the sway bar, so you might have to get Si control arms.
Old Jan 27, 2003 | 08:53 PM
4potnick's Avatar
Default Re: ???88 HF, Rear sway bar and disc brakes??? (88CRXSiB17)
is it possible to put rear disc on a 88? does anyone know? anybody do this?
Old Jan 27, 2003 | 09:01 PM
Speed PHreak's Avatar
Sorry dude, ALL 88's have the "different" suspension. The different suspension that is exactly the same as whats on the ITR's, is a slightly passive rear steering setup. The rear LCA and the shocks they use allow the rear tires to deflect slightly when cornering. It allows a bit better turn in response, although it makes it a bit "twitchy" on such a short wheel base car. All the jap cars 88-91 had this style suspension. Only in america, people bitched about it being "twitchy" so they changed it after '88.
I love my 88's rear suspension, it seems a bit more nimble in the corners than my 91 si. The HF's front sway is tiny and having no rear bar's is def. a hinderence. With a good aftermarket sway bar setup or even stock Si bar's you'd notice a good improvement in handling. DON'T put those damned rear disks on there. The money you'll/he'll spend on that useless conversion could net you some sway bars. The breaking power isn't improved any over the stock drum setup, unless you got with an oversized disc/caliper setup ontop of the conversion.
If you want better stopping power upgrade the front brakes to 90-91 Ex spec 10.3" rotors and calipers. Or hit up REX VT he's got a massive set of front brakes on his Euro spec VTi, like 11" rotors with twin piston calipers ~ all from stock Honda/Acura parts.
[Modified by Speed PHreak, 1:06 AM 1/28/2003]
Old Jan 28, 2003 | 09:05 AM
Timmah!!'s Avatar
Default Re: ???88 HF, Rear sway bar and disc brakes??? (Speed PHreak)
So what about the rear swaybar, can an aftermarket rear swaybar be purchased and instaled without major modafications??
[Modified by azroth, 1:07 PM 1/28/2003]
Old Jan 28, 2003 | 04:19 PM
Timmah!!'s Avatar
To The Top
Old Jan 29, 2003 | 04:47 PM
4potnick's Avatar
anyone
Old Jan 29, 2003 | 05:12 PM
A sway bar kit from suspension techniques would be the ticket. Don't put just an aftermarket rear and not upgrade the front. The tiny 17mm sway on the front of the HF, would make the car very unbalanced handling-wise. It'll most likely have the tedancy to want to understeer.
Old Jan 29, 2003 | 06:48 PM
Vince_badaz's Avatar
I have a friend who has put a suspension techniques rear sway bar for a 89-91 on his 88 crx, so it has been done.
I thin you just have to play with the braket that bolts to the same bolt as the shock on the lca. Maybe you'll have to do a trip or two to Home depot that's it.
There is also a 88 sus tech rear sway bar from Ground control, but it is not the same price than the 89-91 one.
PL
Old Jan 29, 2003 | 07:17 PM
bryant's Avatar
Default Re: ???88 HF, Rear sway bar and disc brakes??? (Vince_badaz)
with the 88's you need the ST adapter kit. I just got the rear bar and adapter kit for my car. Should have it installled soon. I can take pics of the kit if you would like.
akusukacrx
Jan 25, 2008 11:02 AM
SupraRXZ
Suspension & Brakes
Jan 11, 2007 06:01 PM
GI8U2racing
16
Nov 30, 2006 03:31 PM
silver89civic
10
Dec 21, 2003 07:16 PM
