b16a intake mainifold?
Old Jan 27, 2003 | 08:41 AM
NSX Tech's Avatar
Default b16a intake mainifold?
Has anyone put the p73 sir mainifold on a sir1 b16a ?
Old Jan 27, 2003 | 08:54 AM
K-OTIC Racing's Avatar
Default Re: b16a intake mainifold? (NSX Tech)
ill be putting on my manifold from my '99 Si on my b16 motor thats going in my '91... i heard it wont pass a visual smog check with the tps on the back of the manifold.
Old Jan 27, 2003 | 09:41 AM
NSX Tech's Avatar
Default Re: b16a intake mainifold? (K-OTIC Racing)
Thanks but on the sir1 it has a fast idea control valve on the p73 it does not have it
anyone ?
Old Jan 27, 2003 | 09:58 AM
Redline130's Avatar
The tps is on the throttle body
anyone ?
I have a ITR manifold on my b16, I just by-passed it with a longer piece of hose.
[Modified by cyber13, 11:01 AM 1/27/2003]
Old Jan 27, 2003 | 10:12 AM
NSX Tech's Avatar
Default Re: b16a intake mainifold? (cyber13)
So bypass the fast idea valve and use the newer air controler ?
Old Jan 27, 2003 | 10:51 AM
Redline130's Avatar
You are talking about the valve that is on the intake manifold under the throttle body right? Or are you talking about the iacv which is located on the back of the intake manifold? BTW, its fast idle valve.
Old Jan 27, 2003 | 11:54 AM
NSX Tech's Avatar
bypass that ?
upgrade to the newer one
kb0821
Aug 8, 2008 11:56 AM
turboed4life
May 15, 2004 12:14 PM
eg6madness
Jul 24, 2002 09:21 PM
