JDM ecu????
Old Jan 27, 2003 | 08:14 AM
ianp's Avatar
Default JDM ecu????
Just a quickie.
I have a 1996 spec JDM ITR (registered first in 1997). I have been told all JDM ITRs up to end of 1997 run OBD1 ecu, but all run the OBD11 harness is this correct, as it seems a bit strange too me. Also I have read somewhere on this forum (have searched but to no avail) that because I have OBD1 I can run a test pipe and not throw a cel code due to OBD1?????
As i am on the subject what would I need to run hondata using my setup. Its stock at the mo but with possible future upgrades I would imagine I would need something like Hondata.
Any help would be good.
PS Laymans terms if possible.
Old Jan 27, 2003 | 09:50 AM
blykins's Avatar
Banned
Default Re: JDM ecu???? (ianp)
I have a 1996 JDM ITR swap. I have the ECU that came w/ it. It has OBD2 plugs but runs an OBD1 program. So basically you can run it in an OBD1 car w/ an OBD1-OBD2 converter harness, and not throw any CEL's(2nd o2 sensor CEL).
I am using a chipped P28 and i have a testpipe.
[Modified by blykins, 1:52 PM 1/27/2003]
Old Jan 27, 2003 | 10:00 AM
Akira-R's Avatar
Default Re: JDM ecu???? (blykins)
None of the jdm ecus * i run a 99* use a 2nd o2 sensor.
--reid
Old Jan 27, 2003 | 10:01 AM
blykins's Avatar
Banned
Default Re: JDM ecu???? (Akira-R)
--reid
I thought all cars 96 and newer(OBD2) run 2 o2 sensors?
Old Jan 27, 2003 | 10:18 AM
B2FiNiTY's Avatar
JDM ecu is a OBDI style with obd2 plugs. It allows you to run no second 02 sensor like obdI ecus.
Old Jan 27, 2003 | 11:44 AM
mugenracer's Avatar
Default Re: JDM ecu???? (B2FiNiTY)
sorry for hi-jacking this thread slightly, i have a JDM SiVTEC (GSR) with two O2 sensors, one on the collector and one on the cat, as my car is OBD1 does that mean that i can fit a testpipe without throwing a code? And if so what do i do with the O2 sensor, bung it into the testpipe or just remove it altogether?
Old Jan 27, 2003 | 11:59 AM
Nameless RB26's Avatar
Default Re: JDM ecu???? (mugenracer)
96-99 JDM ITR ecu's are OBD1 programming, and OBD2A plug style
00-01 JDM ITR ecu's are OBD1 programming, and OBD2B plug style
I'm going to believe this, although the only thing I doubt, is that the 00-01 JDM ITR ecu's are OBD2B, they might have stayed OBD2A.
They're all the same programs though..
Old Jan 28, 2003 | 02:52 AM
ianp's Avatar
--reid
Thank you for your reply. So if you are correct I can just leave my 2nd o2 sesor flapping in the wind and I wont get a cell code
Old Jan 28, 2003 | 08:29 AM
rbf351's Avatar
i was using a 00 CTR ECU on my 00 Si
the harness plugs are identical and pulg right in
i disconnected my 2nd O2 for a test pipe and never got a CEL
removed the EVAP system no CEL
car also doesn't need to be warmed up for VTEC to work
and there is no speed limiter like some people believe, i was able to hit 140 MPH and would have went faster, but it didn't like the way the car felt
Old Jan 28, 2003 | 11:02 AM
Default Re: JDM ecu???? (rbf351)
You had a wierd ecu then. I've used a 00 CTR ecu, and the car HAS to be warmed atleast half way up. And the speedlimiter, I never bothered checking it out since it was pointless to go that fast.
Old Jan 28, 2003 | 11:37 AM
rbf351's Avatar
Default Re: JDM ecu???? (Nameless)
nothing wrong with my ECU, works perfectly and still does
it does limit your reving if it;s cold but vtec still engages
it lowers the rev limiter to about 7800rpms instead of the normal 8650 rpms
Old Jan 29, 2003 | 11:31 PM
Well can you explain why my vtec would not engage when cold? This is how it was designed (all of them). Yours must have been raped somehow.
You're crazy revving that high on a cold engine..
Old Jan 30, 2003 | 12:09 AM
EK MONEY's Avatar
--reid
yup
angela_itr
Aug 14, 2004 01:11 PM
Project99EK
Jan 30, 2004 08:15 AM
B16b2b
Nov 13, 2002 12:14 PM
Nameless RB26
Nov 1, 2002 06:17 PM
