Timing belt parts
Old Jan 27, 2003 | 07:04 AM
Eluder200K's Avatar
Default Timing belt parts
Ok guys, can someone list off the things i'll need for a Timing belt change? Just parts wise, I don't want to forget anything
Thanks alot
Evan
Timing belt replacment every 80K
Old Jan 27, 2003 | 07:06 AM
migs's Avatar
Default Re: Timing belt parts (Eluder200K)
Belt, Water Pump, tensioner
Misfit's Avatar
belt, tensioner, and water pump.
Old Jan 27, 2003 | 07:12 AM
Eluder200K's Avatar
Default Re: Timing belt parts (MISFIT)
do i need a water pump gasket? Thats everything, just those 3 things?
thanks alot guys (me not being an AARRR and all)
Old Jan 27, 2003 | 07:34 AM
IN VTEC's Avatar
The pump should already have a gasket slapped onto it.
Old Jan 27, 2003 | 07:47 AM
The Toecutter's Avatar
Default Re: Timing belt parts (IN VTEC)
You may want to replace the crankshaft seal behind the timing belt gear. It's 8.00 worth of piece of mind.
Old Jan 27, 2003 | 07:50 AM
Eluder200K's Avatar
ahhh, i found everything on hondaautomotiveparts.com http://www.hondaautomotiveparts.com/...+BELT+%28SI%29
but it's a little confusing, it looks like #12 is the belt and the adjuster stuff all in one package, anyone ever delt with this site before?
[Modified by Eluder200K, 4:51 PM 1/27/2003]
Old Jan 27, 2003 | 07:57 AM
IN VTEC's Avatar
That's the wrong timing belt. You'll end up with a P30 belt instead of a P72....shorter and won't fit.
The belt you're really looking for is:
http://www.acuraautomotiveparts.org/...ING+BELT+COVER
Philly_NBP_R's Avatar
you have to individually select which parts you need - you may want to call or visit the H dealer to get the part numbers... #12 is NOT a combo...
Old Jan 27, 2003 | 07:58 AM
actually it is the RIGHT timing belt - he has a Prelude, not an ARRRR
Old Jan 27, 2003 | 08:21 AM
IN VTEC's Avatar
Default Re: Timing belt parts (Philly_NBP_R)
Well, I'll be derned.
I scanned the URL and only saw the SI part of it....completely taking for granted that it might have been something other than an ITR. God forbid that any other kind of Honda exist.
Old Jan 27, 2003 | 08:29 AM
Eluder200K's Avatar
hahaha, yea, I figured everyone would realize , sorry. It's an 89si prelude if anyone cares
Noone on the other boards knows anything and won't reply because they are too buzy modifiing thier tail lights or something I guess j/k
Old Jan 27, 2003 | 09:00 AM
Eluder200K's Avatar
Ok, thanks for the help everyone, I found all the T-belt stuff plus the crank oil seal and some other little things
Type-R board oWnz
thanks again
Evan
dookeye
Dec 27, 2008 09:06 AM
foxfai
Mar 5, 2008 01:12 PM
jimjonez
Mar 19, 2007 05:00 PM
hkboy87
Jan 5, 2006 07:01 PM
98LS4dr
Feb 1, 2005 11:36 AM
