What the hell makes this sound? This happened on my last car too.
Old Jan 26, 2003 | 11:20 PM
Nameless RB26's Avatar
Default What the hell makes this sound? This happened on my last car too.
When I let the clutch out, I hear a clunk sound. A hollow sounding "clunk."
For a fact, I know it's not:
suspension
mounts
brake system
axles
steering column
So let's rule that stuff out, I would have figured it out already if it was those. This sound comes from my engine/tranny.
Anyways, when I let the clutch out and it grabs, it makes the clunk sound. No one has ever figured it out. I've had people tell me it's the throwout bearing.. but I don't understand how that would make a sound.
I bet some of you can make this sound with your B18's... all you have to do is let the clutch out when stopped (not enough to kill it), and don't rev it high, then listen for that light clunk sound coming from the clutch/tranny area. You can do it over and over (depending on how bad it is). Mine is pretty mild.. but when I had my 98 Integra (LS), it was terrible. It made the sound when I shifted gears too.
Could there be some kind of play along my drivetrain somewhere that could cause this? Could the clutch engagement cause this? Is it the crankshaft? Thrust bearing? Something!!!
I'm beginning to think that the way I drive over a period of time causes this.
I'll be suprised if anyone else can just tell me what it is that makes this sound. Please help me figure it out...
Old Jan 26, 2003 | 11:34 PM
CPR's Avatar
CPR
Default Re: What the hell makes this sound? This happened on my last car too. (Nameless)
I've had the same sound for as long as I can remember. After my 15K service, in which they adjust the clutch, the sound went away for a little bit and then came back. I then had my clutch, t/o bearing, pressure plate replaced under warranty with 16K miles on the car and the sound went away for a bit, only to come back. With 35,300 miles, I the same things mentioned above, in addition to a flywheel, replaced under warranty. I've been on the new clutch for 700 miles. All was well until the past couple of days where I'm starting to notice the sound again. It comes and goes and just as long as the car drives fine, then I not worrying too much about it.
Old Jan 26, 2003 | 11:35 PM
skafia's Avatar
25 Year Member
Default Re: What the hell makes this sound? This happened on my last car too. (CPR)
When I slam on my brakes I hear a loud clunk coming from my front suspension.
Old Jan 26, 2003 | 11:40 PM
Default Re: What the hell makes this sound? This happened on my last car too. (skafia)
But this has nothing to do with the suspension. This is a sound I can make when fooling around with the clutch and you don't need to be moving. But on a side note, my rotors/pads/calipers make a clunk sound too when i slow down just right coming to a stop.
Anyways, I think this is probably something all integras have, I've also heard it on a friends GSR. Although some people probably make it worse by clutch dumping or just driving a little bit different than others. Although I think I drive just fine..
My g/f's Si makes the sound too, but it's really really light..
What the **** does it? It's like an engagement sound, but it's a rough clunk.
Old Jan 27, 2003 | 04:17 AM
RiceRyder's Avatar
In my humble opions i think this noise is very common for fwd cars.
Old Jan 27, 2003 | 07:06 AM
june's Avatar
Default Re: What the hell makes this sound? This happened on my last car too. (RiceRyder)
Damn and to think I was going crazy. Now I feel better. I was wondering the same thing. Keep the questions and answers coming please . I need to find out why that sound keeps coming.
June.
Old Jan 27, 2003 | 07:11 AM
june's Avatar
I get that very same sound too. It's been bothering me for quite a while now. I also get a little viberation at around 50 mph+ I was thinking it was my lsd because it started happening after I raced my hatch at the track. Does anybody know what my problem could be?
June
Old Jan 27, 2003 | 07:51 AM
Hooch'n's Avatar
Default Re: What the hell makes this sound? This happened on my last car too. (june)
Could be a whistle tip!
WooWoo
Old Jan 27, 2003 | 09:09 AM
JD_B18CDX's Avatar
I'd like to know too.
Although I dont have an ITR, I do get that "clunk" thingy on my hybrid. Usually occurs when the car is on an uneven surface. Like when backing out on driveway diagonally and the last tire is still on the driveway (compressed suspension). When I slowly let go of the clutch to move forward, I get a "clunk".
Its not the clutch throw-out bearing or the clutch because I just replaced that with new ones.
Its drving me nuts and I cant figure out what it is.
My theory is its the motor twisting on the engine mounts.
[Modified by JD_B18CDX, 1:12 PM 1/27/2003]
Old Jan 27, 2003 | 11:10 AM
Default Re: What the hell makes this sound? This happened on my last car too. (JD_B18CDX)
Bump..
I'm thinking it might have something to do with the tranny..
Anyone else? I know there's alot of people who can hear this..
Old Jan 27, 2003 | 11:40 AM
Eva01's Avatar
.Hmm...I don't get that noise at all. Strange
Old Jan 28, 2003 | 11:20 AM
Default Re: What the hell makes this sound? This happened on my last car too. (Eva01)
anyone else?
Old May 12, 2013 | 03:19 PM
JimmyJizzle's Avatar
this is an old thread, but i need an answer, when i engage, i hear a metallic clank, and just today i went around a corned semi quickly and the same thing happened, i am running an open DP and i can hear it over that, help!
Old May 12, 2013 | 06:35 PM
soulassassin13's Avatar
I have assumed that it is the front sway bar.
Old May 12, 2013 | 06:52 PM
cmdr430's Avatar
Check the rear motor mount
Old May 12, 2013 | 06:59 PM
^ Could be that was well. Come to think about it, my car hasn't made that clunk since replacing my motor mounts in November.
Old Jun 13, 2013 | 07:30 AM
Gregjnolan's Avatar
I hear the same sound in my 01 R. No idea what tho
Old Jun 19, 2013 | 11:24 PM
alsxe10's Avatar
heard it in my R as well, have no idea where's it coming from. on a side note my friend's 02 accord makes the same noise. but was gone when he swapped coilovers, so I am thinking maybe its coming from the bolts of the LCA?
EG_SINZ
Transmission & Drivetrain
Mar 6, 2016 11:38 AM
DomenEK
Jun 2, 2006 06:44 PM
JamesV
15
Jan 11, 2006 12:17 AM
2000gsrsedan
Aug 26, 2003 12:05 PM
tommyboy
May 7, 2002 09:26 PM
