wierd sound when i disengage the clutch.. [ video ]
hey this sound is bugging me.. i dont know if its normal.. im guessing the clutch is messed up but it doesnt slip or anything.. someone help
Heres a video of the sound.. you can tell because it goes .. grrwrwrwrrwrr
the sound only happends when i clutch out.. once the clutch is pushed it goes away..
:: LINK ::
http://media.putfile.com/Movie922727
:: LINK ::
Re: wierd sound when i disengage the clutch.. [ video ] (7808)
tranny shifts fine.. its just very wierd. the last owner said it was like that when he bought it.. i dont plan on swapping the engine in awhile just bugs the hell out of me
well in the video i can barley hear the noise, so i'm not even sure if i herd the right noise. but when you let go of the clutch pedal the noise gets louder or softer?
Re: (lv6l)
its your input shaft bearing on the tranny
https://honda-tech.com/zerothread?id=596873
replaced it on my b16 tranny
took me about a day to do it
wasnt hard
wasnt hard
Re: (lv6l)
that sounds is comming from your clutch. so imma guess its clutch chatter.
it can either be a
loose flywheel
clutch not disengaging all the way
or really a fucked up bearing.
i cant think of anything else becase your motor is fine and your tranny is fine so it must be somewhere in the middle.
it can either be a
loose flywheel
Re: (Danger Hart)
I dont have the badwith to listen to it (56k), But I'm going to take a guess that its the release bearing. I've replaced many of these due to the same sound your hearing. It takes about 3 or 4 hours to relace depending on the tools and experience you have. The bearing costs like 40 bucks from Honda.
Re: (komat)
i dont know.. br1anpham saw my motor and said its not the motor thats suppose to be in the cx.. i dont know what tranny it has.. how can i identify its a cx tranny?
Re: (JamesV)
Who cares what kind of tranny it is. Any D-series tranny will bolt up. But the problem is; even if you buy a whole new tranny, the release bearing could still be bad. Don't buy a new trans. just replace the release and pilot bearing. That should fix all!
Dont think too much into the problem and replace things that dont need replacing. That's the biggest problem people have. Just figure out the main problem and fix it. If it consists of the tranny being replaced, then replace it. But don't go to extremes.
