What do you all think of my junkyard IC pipes? pics
Old Jan 26, 2003 | 06:11 PM
asianspeed's Avatar
Default What do you all think of my junkyard IC pipes? pics
I used the hoses off of a dsm car as well as misc rubber hoses I pulled from misc cars. They mostly 1 3/4" in diameter and I used aluminum exhaust pipes to connect them together. Will this be suffucient to run about 8 psi of boost?
[Modified by asianspeed, 10:12 PM 1/26/2003]
Old Jan 26, 2003 | 06:12 PM
evoeone's Avatar
Default Re: What do you all think of my junkyard IC pipes? pics (asianspeed)
it should hold up. not bad for junyard dyi setup just tighten the **** out of teh clamps, and i think 8 psi will hold
Old Jan 26, 2003 | 06:13 PM
YumVTEC's Avatar
ghetto... don't plan on running a lot of boost.
Old Jan 26, 2003 | 06:16 PM
lazerus's Avatar
Default Re: What do you all think of my junkyard IC pipes? pics (YumVTEC)
should hold up no probs. i would recommend buying some piping when you can afford it and get it done a little better.
Old Jan 26, 2003 | 06:22 PM
asianspeed's Avatar
Why shouldn't I run a lot of boost? Is it because of the small piping diameter and how much air it can flow? Or is it because the connections might get blown off?
Old Jan 26, 2003 | 06:27 PM
Lei Siew Long's Avatar
save up for some real intercooler piping.
Old Jan 26, 2003 | 06:40 PM
TurboCRVTEC's Avatar
Default Re: What do you all think of my junkyard IC pipes? pics (boostedeg6)
yep definitely junkyard stuff
Old Jan 26, 2003 | 06:46 PM
Broken Gearbox's Avatar
Default Re: What do you all think of my junkyard IC pipes? pics (TurboCRVTEC)
...Ghetto superstar!!
Old Jan 26, 2003 | 07:00 PM
ludelvr's Avatar
I suggest either using the heavy duty t bolt clamps or place a bead of weld around the edges of your aluminum tubing, this way the rubber hoses have something to grab onto! My pipes kept blowing off because I wasn't using either. IMO, you can run higher boost but if you don't do either of these, the pipes will blow off.
Old Jan 26, 2003 | 07:38 PM
Joseph Davis's Avatar
Default Re: What do you all think of my junkyard IC pipes? pics (ludelvr)
I give you an A for creativity. Your car will be the one grading you on feasability. In the meantime, thumbsup - I can't see any reason for failure unless you have low grade coolant hose too close to the compressor outlet. Coolant hose will handle plenty of psi, how well it handles heat near the compressor outlet remains to be seen.
ludelvr makes a good point about the hoses slipping off. I'm a big fan of cutting a tiny groove in the pipe for the hose to bite down into when a clamp is tightened onto it... but the bead setup works just as well.
VI Boost
May 19, 2006 08:03 AM
BlueShadow
Jul 9, 2005 09:18 PM
98_4drCivic
May 27, 2005 08:54 AM
Tetronious
May 3, 2005 06:14 PM
Dancing is Forbidden
Jan 9, 2004 11:07 PM
