Leaking hatch window
Old Jan 26, 2003 | 03:23 PM
crXtreme_girl's Avatar
Default Leaking hatch window
I did searches but found nothing on this topic.
My CRX leaks water when it rains from either side of the hatch window. I thought it would be the seals, so when I took it to a Honda place to get other work done, they didn't think it was the seals. But when they looked at it they couldn't find the problem at all.
its a 90 dx.
any help would be much appreciated.
Old Jan 26, 2003 | 03:41 PM
uneek4dr's Avatar
Default Re: Leaking hatch window (crXtreme_girl)
i had the same problem. never figured out how it was leaking in. now my 4dr civic leaks in the front windows somehow.....i can see the water on the side of the dash but cant figure out how its gettin in or where exactly
Old Jan 26, 2003 | 04:51 PM
Default Re: Leaking hatch window (uneek4dr)
its a frustrating problem cuz Honda couldn't figure it out. i don't want to spend the cash to get someone else to look at it too, cuz then all i'm doing is paying labour cost without the problem being fixed. i'm sick of everything getting wet. oh grrr
HELP!
Old Jan 26, 2003 | 04:52 PM
bryant's Avatar
Good luck, its just one of those things with an older car. I guess you could go buy some caulking and take out the intioir plactic and seal around it and hope that works. Best of luck, and let us know if you figure anything out.
If its leaking from the front glass, then just reseal the top part. Thats your best chance and its pretty easy to do.
[Modified by Bryant, 6:54 PM 1/26/2003]
Old Jan 27, 2003 | 07:28 AM
Geezer's Avatar
Other folks have traced this problem to clogged sunroof drain tubes. The water then runs along the headliner until it comes out at the rear hatch. When I was stripping my CRX to race, I found one of the drain tubes completely full of water.
Old Jan 27, 2003 | 07:33 AM
keithv's Avatar
Default Re: Leaking hatch window (Geezer)
a dx won't have a sunroof, so that is probably not her problem.
here are some topics to look through:
https://honda-tech.com/zerothread?id=361999
https://honda-tech.com/zerothread?id=362617
https://honda-tech.com/zerothread?id=307798
Old Jan 27, 2003 | 08:22 AM
E-AT_me's Avatar
Default Re: Leaking hatch window (breaka_1_9)
if you have a rear windshield squirter, it can come in from there, too.
Old Jan 27, 2003 | 09:58 AM
guttedEF's Avatar
Default Re: Leaking hatch window (Rexman)
On my '90 STD, I kept finding puddles in the rear where the spare tire is. It ended up being the taillights leaking. I just sealed them up with some silicone and no more leaking.
I've also seen this problem on several other friend's hatches. Just look in your taillights after a hard rain and see if there's water inside. When I noticed it, I wasn't even looking for the leak.
Old Jan 28, 2003 | 01:31 AM
uneek4dr's Avatar
Default Re: Leaking hatch window (guttedEF)
on my car it seems like the side view mirrors are allowing water to come in but i dont see water there....its strange though cuz it only happens on whichever side of the car is faceing up the hill when its parked sideways. im guessing the sideviews are leaking but i guess when its warmer ill try to use some caulking and fix the prob. anyone know if CRX or hatch side views fit a sedan? i want some diff imrrors and they really only make the other styles for a crx or hatch and not my car.
Old Jan 28, 2003 | 05:19 AM
ricodemus's Avatar
I am having this problem too. I noticed that the gasket had broken. where did you seal? On the tail light - car interface?
Old Jan 28, 2003 | 05:24 AM
Hondasaurs's Avatar
Check your weather stripping to. I had the same problem.
drew2
Jul 23, 2006 10:08 PM
DC4noMore
Apr 15, 2004 11:58 PM
yusoslo
12
Oct 22, 2003 09:03 PM
integra97R
Oct 3, 2003 09:13 AM
4potnick
Aug 30, 2002 08:47 AM
