10 MM Female Tee
I am getting all of my plumbing situated for a turbo swap coming up soon and I want to change out my oil feed plumbing. I have a turbo charged and built S2000. I am tapping the oil pressure sensor on the side of the block. The pipe thread is 10mm, 1 or 1.25 pitch.
I want to run a male to male 10mm to 10mm fitting to a 10mm female T pipe. On one side of the T I want the oil pressure sensor, and on the other side I want a 10mm to -3 AN fitting.
The problem is that there is a huge lack of AN to metric and back plumbing. I could hook up a 10mm to -4 to a -4 female T, but there is no -4 male to 10mm female to plug the pressure sensor back in..
Also, someone was telling me that 10mm pipe will thread in to 1/8th pipe for a ways, and with tape around it, it will seal just fine???
Anyone know where I can get a 10mm female Tee?!?!?!?
Chris
Chris
10mm is the size of the head of the bolt itself, not the size of the thread. most 10mm bolts have 6 x1.0mm thread, while 10 x1.25 bolts is a big difference, at elast 4 mm in diffferences in radius...
most s2000 turbo kit, requires an oil filter relocation kit since you will have a hard time fitting an oil filter with the turbo next to it....you'll need to run an oil filter relcoation kit and you can tap the oil feed line from the relocation kit adapter..
stan
stan
if i'm not mistaken, the oil sending unit on the s2000 is just like any other honda, 1/8" BSPT. An M10 x 1.25 bolt is pretty close to the same diameter as the sending unit so this may be the confusion. Most likely you need the same T that every other turbo honda uses. Like stan said though, you will probably need to relocate the filter.
You must be right!!! Thanks so much Tony, I will try and get that today at the local hydrolics/aeroquip location.
Thanks for the help!
Chris
PS- I envy you
(seriously) You're one of the few people I truely look up to in the industry.
Chris
PS- I envy you
Shoot,
Tony, the local hydraulic place doesn't have any female 1/8" bspt fittings. Do you know where I can get one? Also I will need a male to male 1/8th BSPT fitting and a 1/8th BSPT to -3 AN
Please help!
My email is chris@chrisdrivesafastcar.com
Thanks
Chris
Please help!
Thanks
Chris
Stan, please give me a contact phone number!!!
Email to chris@chrisdrivesafastcar.com or let me know what your email address is and I will get in contact with you.. (I can't figure out how to get email addresses on the forums???)
Stoich EG2
Jun 9, 2006 09:34 PM
egizzle8
Mar 9, 2004 09:07 PM
Zeus Zore
Sep 7, 2003 03:04 PM
I sent an email mid today and no response .. heheh
