Help diagnose problem: backfire, cel on and off
Old Jan 26, 2003 | 09:51 AM
jdm169's Avatar
Default Help diagnose problem: backfire, cel on and off
I just got this crx and have been trying to diagnose the problem. I feels as though the car is choking and is sputters and backfires. The check engine light will come on but then go off and come back on( light doesnt always come on, seems when driving for like 15 minutes or longer) The thing is, it doesnt throw any codes. The ecu is blank. What's the deal?? anyone have any ideas
I did an oil change, changed the plugs, adjusted the valves( they were noisey)
also - when i took the valve cover off do adjust the valves i noticed there was oil leaking down all over the plugs i know i need new valve cover gaskets. I cleaned out the oil but it's probably leaking down again. could that be it...
if oil is leaking down there could that cause it to burn oil and blow smoke or is that another problem all together
please help all comments welcomed thanks
Old Jan 26, 2003 | 10:03 AM
jdm169's Avatar
Default Re: Help diagnose problem: backfire, cel on and off (jdm169)
anyone?
Old Jan 26, 2003 | 11:35 AM
RCautoworks's Avatar
Not sure, but could it be the timing ? Just a thought.
[Modified by 90blackcrx, 2:35 PM 1/26/2003]
Old Jan 26, 2003 | 12:35 PM
jdm169's Avatar
Default Re: Help diagnose problem: backfire, cel on and off (90blackcrx)
anyone else have ideas?
Old Jan 26, 2003 | 03:24 PM
spettinger's Avatar
does the car idle smoothly? might be the plug wire order on the distributor. what are the compression numbers?
Evilwayz24
Sep 1, 2009 03:38 PM
WanaBeFaster
May 6, 2007 08:17 AM
Takumi Fujiwara
Jan 31, 2006 07:52 AM
alb_accord
Feb 1, 2005 03:38 PM
RICE POLICE SIP
Dec 19, 2002 10:31 PM
