How do you remove the headliner?
Old Jan 26, 2003 | 12:12 AM
T_Rex's Avatar
Default How do you remove the headliner?
I want to install a fuba-style antenna where the rear window squirter is, but I'm afraid I'll damage the headliner trying to remove it. How difficult is it to remove? Thanks.
Old Jan 26, 2003 | 01:42 AM
JaiDM's Avatar
Default Re: How do you remove the headliner? (T~Rex)
cant you just unscrew that plastic screw behind the doom light? and access the wisher squiter that way?
Old Jan 26, 2003 | 02:30 AM
shorty91's Avatar
Default Re: How do you remove the headliner? (JaiDM)
why do you want to put a "fuba-style" antenna on there?? isnt that liek using "racing" floor mats?? get the real thing....seen REAL FUBA's on some VW sights for liek $35 brand new....16 foot long cable, base and antenna. get the real thing
Old Jan 26, 2003 | 04:53 AM
keithv's Avatar
Default Re: How do you remove the headliner? (shorty91)
you will need to remove:
- the plastic screw in the rear middle of the headliner.
- the sun visors
- the rear view mirror
- the interior light
- i'm not 100% on this, but the plastic pieces around the rear windows
- the rear oh **** handles if you got them
there might be more. this is all from memory...
Old Jan 26, 2003 | 08:28 AM
G-reX's Avatar
Default Re: How do you remove the headliner? (breaka_1_9)
also you have to remove your door pillars because they run right to the back. Oh and just be jentle when taking the liner down its prittle. Also does anyonee know how to remove the washer squirter?
Old Jan 26, 2003 | 09:52 AM
T_Rex's Avatar
Well, when I bought it on eBay, it was advertised as the real thing, but I don't know for sure. I think maybe the real ones are the ones with the longer, skinnier antenna.
Here's what it looks like:
[Modified by T~Rex, 10:55 AM 1/26/2003]
Old Jan 27, 2003 | 10:56 AM
T_Rex's Avatar
Default Re: How do you remove the headliner? (G-reX)
Not sure what you mean by, remove the door pillars?
Old Jan 27, 2003 | 12:10 PM
keithv's Avatar
the foor molding is the interior molding that goes down the a-pillar (the sloped piece of metal that is in between the windshield and the door).
Old Jan 27, 2003 | 12:13 PM
incubus's Avatar
he means the A-pillar plastic. It just snaps right off. also there are snaps under the back plastic (one the dome light overlaps) that must be taken off carefully with a panel remover. If you dont have one use a phillips head screw driver with the head wrapped in electrical tape to keep from puncturing the liner.
When I took my sun visors off in the summer and put them back up they no longer go all the way up. they stick down like 3". does anyone know how to fix this?
It is somewhat annoying cause they are almost at eye-level.
Old Jan 27, 2003 | 12:33 PM
keithv's Avatar
Default Re: How do you remove the headliner? (incubus)
there should be a screw on the underside of the sun visor. flip the visor down and there should be a screw to tighten the visor to the mounting bracket.
Old Jan 28, 2003 | 09:23 PM
incubus's Avatar
not sure where u r talking about breaka...
could someone post a pic.
the only screws I noticed were the (2)torx screws that hold it into the headliner.
Old Jan 29, 2003 | 03:48 AM
keithv's Avatar
i could have sworn there were set screws which would allow you to tighten the sun visor to the mounting bracket. yesterday when i looked at the ones in my 99 teg, i noticed the screws weren't there. so i don't know what to tell ya...
i do have some sun visors for sale. IM me for details.
Old Jan 30, 2003 | 07:27 AM
incubus's Avatar
thanks, I think I just need to take them off and try to put them back on when I get the chance.
D16Z6racing
Jan 18, 2011 08:05 AM
Mordeki
Apr 19, 2007 07:57 PM
stevescivic
Dec 28, 2005 07:17 PM
dsmIA
Aug 9, 2005 10:33 AM
krack
Jun 25, 2004 09:20 AM
