how much torque do i need for 91 accord head bolts?
Old Jan 25, 2003 | 06:53 PM
50shotRex's Avatar
Default how much torque do i need for 91 accord head bolts?
i am ready to replace my head gasket, but am not quite sure on how much torque is required for each head bolt...please let me know where i can find this information please...
Old Jan 25, 2003 | 07:03 PM
ratherbewalking's Avatar
Default Re: how much torque do i need for 91 accord head bolts? (50shotRex)
on the 1990-93 accords, tighten the bolts to 29 ft lbs (40 nm) on the first pass 51 ft lbs (70 nm) on the second then tighten them to thier final torque, 72 ft lbs (100 nm)
make sure to tighten in sequence
Old Jan 25, 2003 | 07:24 PM
50shotRex's Avatar
Default Re: how much torque do i need for 91 accord head bolts? (ratherbewalking)
thanks for the help Ratherbewalking, and what exactly do you mean by 1st , 2nd, and final pass? is it when i run the engine for a couple of minutes? thanks again!
Old Jan 25, 2003 | 08:53 PM
noooo, you do your first pass on all the bolts, at a certian tq, then a second, then a third. make sure and use new oil on the bolts when you thread them in
Old Jan 25, 2003 | 09:17 PM
rustyeleio's Avatar
Just in case...make sure you get out any oil and crap in the holes. any fluid in them and the bolts wont torque down correctly. use q-tips taped to a stick or something. be sure to follow ratherbewalking's steps or you may warp the head. good luck.
Old Jan 28, 2003 | 08:50 AM
50shotRex's Avatar
Default Re: how much torque do i need for 91 accord head bolts? (rustyeleio)
thanks again guys!
EugeneTheBeast
Engine Machining & Assembly
Jun 2, 2019 06:48 PM
TunerKid4lyf
25
Jul 12, 2013 08:01 AM
orangeracer
May 23, 2006 03:32 PM
Hybrid
Oct 11, 2002 10:44 AM
