Hot Cold dial for heater/ac broke. How to replace?
Old Jan 25, 2003 | 06:27 PM
buckeyefan's Avatar
Default Hot Cold dial for heater/ac broke. How to replace?
Anybody ever fix one of these? It's stuck on cold and I can't get the windows defrosted. Is this an expensive thing to fix? Labor and parts wise?
Old Jan 25, 2003 | 06:44 PM
Hondaaccordvtec's Avatar
Default Re: Hot Cold dial for heater/ac broke. How to replace? (buckeyefan)
Is the dial broken? or will it move but just no temp. change? If the dial is broken, they just pop off and you put a new one on. If there is no temp. change when you turn the dial, sounds like your temp. cable is broken. Look underneath the glove box on the passenger side. You will see a cable attached to a white box?!? This cable is what controls your temp. You will need to see if it is sticking. Tuen your temp. dial and see the cable moves. If it doesn't that's your problem.
Old Jan 25, 2003 | 07:11 PM
buckeyefan's Avatar
Default Re: Hot Cold dial for heater/ac broke. How to replace? (Hondaaccordvtec)
The **** is fine. It feels like it works part of the way, then it turns real easy. (like it's not doing anything.) I'd be happy just to turn it all the way to the right for heat. At least I could drive it. Do you think the cord is broke, stripped, or just slipped off?
Old Jan 25, 2003 | 07:14 PM
Sound like the cable has come loose. Like I said before, look under the glovebox on the passenger side. Turn the temp. dial and see if the lever moves with the cable attached to it.
Old Jan 25, 2003 | 09:53 PM
cyrixvsp2's Avatar
my cable was unhooked. you have to take the dash trim off, then unbolt the heater controls and then either something will be broken and need to be replaced or you'll jsut have to hook the cable back up. it's not that hard once you open it up.
Old Jan 25, 2003 | 09:59 PM
sloaccord's Avatar
New User
try pulling it off. the plastic part is known to snap- just look, for giggles.
Old Jan 26, 2003 | 01:27 PM
YodiBrodi's Avatar
Default Re: Hot Cold dial for heater/ac broke. How to replace? (sloaccord)
always check the simplest thing first. exact same thing happened to me. pull it off and look. $6 for a new one i think
Old Jan 27, 2003 | 05:27 AM
KCHybrid's Avatar
Default Re: Hot Cold dial for heater/ac broke. How to replace? (YodiBrodi)
Yup and the guy I bought the new from at honda said they brake all the time. I have replaced both of mine so far, defentily try the easy things first. Keep It Simple Stupid
r_kage
Dec 6, 2016 10:31 AM
SpeedOFsmell
Mar 15, 2014 06:14 AM
viciousef9
Feb 27, 2008 06:27 PM
Nataku
Sep 27, 2005 05:30 PM
superthug
Oct 18, 2003 09:22 PM
