CAI for b18a in second gen CRX
Old Jan 25, 2003 | 01:36 PM
jasonb's Avatar
Default CAI for b18a in second gen CRX
For those with an LS motor in a second gen CRX, what cold air intake works for this setup? A friend of mine just bought a CRX with an LS motor and would like to add a CAI.
Old Jan 25, 2003 | 05:15 PM
crew08 (girlygirlracer)'s Avatar
Default Re: CAI for b18a in second gen CRX (jasonb)
good question, i wanna know too but for a crx with a gsr motor.
Old Jan 25, 2003 | 07:05 PM
jasonb's Avatar
Default Re: CAI for b18a in second gen CRX (crew08)
now that you mentioned that, does anyone know what CAI's would work for an LS/VTEC with a GS-R head?
Old Jan 25, 2003 | 08:05 PM
Jeff C's Avatar
Just get one for a crx...it will work.
Old Jan 25, 2003 | 11:43 PM
RCautoworks's Avatar
Default Re: CAI for b18a in second gen CRX (Jeff C)
Would'nt the crx cai diameter be to small ? I would say go with a b series cai, I would go with a 00 si cai.
[Modified by 90blackcrx, 2:44 AM 1/26/2003]
Old Jan 26, 2003 | 06:02 AM
Flexmyrex's Avatar
Default Re: CAI for b18a in second gen CRX (90blackcrx)
i have a ram air, 90-93 teg. fits perfect
the cai will prolly work too
Old Jan 26, 2003 | 06:35 AM
UncleBen'sRacing's Avatar
Default Re: CAI for b18a in second gen CRX (flexmyREX)
ok lets put it this way
lsvtec, gsr, b18b, b16a, crvtec, and D series (si version) all take the same cold air intake, as long as you make sure that it is at least 2.5" mandrel bent you should be fine on a b series set up, just get one for a crx that has a 2.5" mandrel bent tube
thx
Old Jan 26, 2003 | 07:46 AM
Agent#ONE's Avatar
Default Re: CAI for b18a in second gen CRX (AllMotorEF9)
just buy the AEM peice for the 99-00 si coupes
fits directly in the crx bay with a b motor.
Old Jan 26, 2003 | 08:26 AM
Malgerus's Avatar
Default Re: CAI for b18a in second gen CRX (Agent#1)
You forgot to mention that you need to relocate the battery.
Old Jan 26, 2003 | 08:54 AM
Agent#ONE's Avatar
Default Re: CAI for b18a in second gen CRX (Mr. S)
well yes you may want to, or just get a smaller battery.
i did however do the relocating of my battery in the crx. but before i did a b swap
Old Jan 26, 2003 | 10:27 AM
jasonb's Avatar
ok, thanks guys. My friend already relocated the battery to the rear of the car. do you guyd know which B series CAI has 2.5" piping? the 99/00 Si intake?
Old Jan 26, 2003 | 11:02 AM
Yeah the 00 si intake will be fine.
Old Jan 26, 2003 | 11:52 AM
red civic standard's Avatar
aem will be coming out with their new cold air intake, the V2 which starts out much larger (4 inches) and then tapers.
Do you think that the 99-00 Si V2 will fit into an ef?
Old Jan 27, 2003 | 07:30 AM
Jeff C's Avatar
I am using the oem intake system from a 91 Si HB on my crvtec'd crx si and it works fine.
Yea, the 99-00 Si cai with a relocated battery is the way to do it.
Old Jan 27, 2003 | 10:00 PM
Yeah I never said it would not work, but you want to match the cai with the throttle body the best as possible.
Old Jan 28, 2003 | 05:38 AM
nsxmatt's Avatar
The correct b-series intake diameter is 2.75 not 2.5. 2.5 is the D-series intakes.
Old Jan 29, 2003 | 06:37 AM
Default Re: CAI for b18a in second gen CRX (nsxmatt)
good call
Old Jan 29, 2003 | 06:50 AM
Charlie Moua's Avatar
ok you'll be FINE with a crx/ef CAI.
*If you think you motor is going to be reving like in the 8k range get the CAI for the 99 si (2.75) you will have to move battery. Fits perfect and looks great.
If you are really really seriouse about doing a B18b all motor get a ITR cai which is 3inch piping.
I have the ITR CAI for my B20
Old Jan 29, 2003 | 08:02 AM
Agent#ONE's Avatar
Default Re: CAI for b18a in second gen CRX (Charlie Moua)
we are glad that u have this, but hes got an EF chassis, not a 92+ chassis.
the itr CAI will NOT work,
the best fit, and performance AVAILABLE for these types of cars with swaps is the 99-00 Si aem cai.
thank you.
Old Jan 29, 2003 | 11:07 AM
thank you.
Thats what I have been trying to say
Old Jan 29, 2003 | 08:43 PM
StorminMatt's Avatar
Not true. AEM LS intakes actually use 2.5 inch tubing. So if you just get the CAI for the CRX, you will be fine. The 2.75 inch tubing is only used on DOHC VTEC applications (B16A, B17A, and B18C1). The only other exception is the ITR, which uses 3 inch tubing.
[Modified by StorminMatt, 5:44 AM 1/30/2003]
rewerbcrx
17
Feb 16, 2006 05:57 PM
Loaded Butane
Mar 17, 2004 12:56 PM
jasonb
Jan 26, 2003 01:03 PM
dingusjt
Nov 11, 2002 06:59 PM
