no spark, WTF?
Old Jan 25, 2003 | 01:28 PM
2k1_ITR_0736's Avatar
Default no spark, WTF?
We just finished (for the most part) the swap in that ed9, and we arent a getting a damn bit of spark. WTF can we do. i mean i changed the plugs/wires, and still nothing, anyone run into a stupid thing that might fix it, other that a coil/distrocap?
Tried the search function, not a damn bit of help.......
And if it is the Distro/coil, what model would i go to buy? Is the del slo VTEC one the same or is that different too?
Old Jan 25, 2003 | 01:39 PM
JoshDM's Avatar
Default Re: no spark, WTF? (2k1_ITR_0736)
igniter/ignition module
Old Jan 25, 2003 | 02:47 PM
PaImportTuner's Avatar
no spark??
replace rotor and dizzy cap(rotor could be detached..broken screw, cap/rotor could be too old/worn)
then
check ignitor and coil(burnt out, faulty)
then
its most likely the dizzy(since its a swap not all b16s come with good dizzys or garauntee to i believe)
when my hatch wouldnt get spark i just replaced Dizzy and it wouldnt start then i bought a new cap/rotor and it then started nicely. Got old dizzy checked out it was messed up as well as cap/rotor.
Are you throwing any codes on the ECU?
Old Jan 25, 2003 | 02:51 PM
Default Re: no spark, WTF? (PaImportTuner)
ok, well i cehcked, and we have power at the coil pack. i cleaned up the rotor contact, and the distro cap contacts witha lil sandpaper. still nothing. so i got my buddy pickin one up right now.
Old Jan 25, 2003 | 02:56 PM
Hondasaurs's Avatar
THis ignitor is expensive. I've got two of them laying around here. I'm up by Albany. I could overnight you one if you want.
Old Jan 25, 2003 | 03:16 PM
Default Re: no spark, WTF? (ZC_CRX)
i could come up and get it. How much you want for it.
[Modified by 2k1_ITR_0736, 7:22 PM 1/25/2003]
Old Jan 25, 2003 | 03:28 PM
0554's Avatar
make sure the ground on the themostat is grounded or someplace on the back of motor and that the battery ground is on the car also.
Old Jan 25, 2003 | 03:32 PM
Default Re: no spark, WTF? (b16a12seccrx)
well the coil pack is well gorunded, as is the car, i tested it. but im open for any suggestions i guess, maybe i will just wrap the whole damn block in tin foil and solder it to the frame rail or something.
Old Jan 25, 2003 | 03:57 PM
also, what the hell is the eavc? i guess its on the intake manifold? i dont see anything under there.
Old Jan 26, 2003 | 09:15 AM
ttt. well its not the coil, or ignitor, still no spark. what the hell? HElp.
Old Jan 26, 2003 | 10:03 AM
come on peeps. Help me out.
Old Jan 26, 2003 | 11:56 AM
keithv's Avatar
really dumb thing to add, but do you have the valve cover to chassis ground strap? don't ask me how why i ask this...
Old Jan 26, 2003 | 12:01 PM
Hondasaurs's Avatar
If you take your time to drive up here I'll give it to you.
Old Jan 26, 2003 | 02:43 PM
how far away are you from SUNY albany?
Old Jan 26, 2003 | 02:47 PM
all the parts seem to working fine, i tested them, and everyhting seems to be OK, why am i not getting spark? i have brand dew wires and plugs.
Old Jan 26, 2003 | 02:48 PM
89civicdx's Avatar
I once did a swap and couldn't get the car to start...checked everything> I forgot to plug in the ecu
Old Jan 26, 2003 | 03:27 PM
Default Re: no spark, WTF? (89civicdx)
Oh damn thats what it was too... NOT. j/k heee
stupid *** thermo ground.
i tip my hat to b16a12seccrx
Thanks For the input peeps.
[Modified by 2k1_ITR_0736, 7:29 PM 1/26/2003]
[Modified by 2k1_ITR_0736, 7:30 PM 1/26/2003]
Old Jan 26, 2003 | 04:09 PM
Hondasaurs's Avatar
I could meet you at Crossgates mall. Its right by there. I live about 40 min from SUNY Albany.
spoonhbk11
11
Jun 9, 2019 07:03 PM
toeknee360*
Oct 5, 2009 11:57 PM
Urban Business
12
Dec 22, 2002 12:28 AM
crxzc
Jun 9, 2002 06:50 PM
96whitels
Aug 19, 2001 02:06 AM
