88-89 and 90-91 si ecu
Old Jan 25, 2003 | 12:22 PM
Crxfanatic15's Avatar
Default 88-89 and 90-91 si ecu
Is there any diffrence between the two?
Old Jan 25, 2003 | 01:06 PM
Hondasaurs's Avatar
Default Re: 88-89 and 90-91 si ecu (Crxfanatic15)
They are all PM6
Old Jan 25, 2003 | 02:03 PM
QuickHonda's Avatar
Default Re: 88-89 and 90-91 si ecu (ZC_CRX)
Yes and no. I know the 88 and perhaps the 89 have slightly different circuitry inside but they do the same job and can be interchanged 90 and 91. The fuel and spark maps in the 90 and 91 might be a little different cause the cams are different for those years but i've never noticed a difference when swapping the ecu.
Old Jan 25, 2003 | 02:06 PM
Default Re: 88-89 and 90-91 si ecu (QuickHonda)
The reason i wanted to know is on ebay they have ecu chips and one says if you dont have a 28 prong chip then you cant use it. I didnt know if there was a diffrence in chipping
Old Jan 25, 2003 | 02:09 PM
Urban Business
Guest
Posts: n/a
88-89 cant be chipped. 88-89 have a 6800rpm fuel kill while most 90-91 have 7500 or none
[Modified by TorteX, 5:09 PM 1/25/2003]
Old Jan 25, 2003 | 02:37 PM
Hondasaurs's Avatar
The 90-91 PM6 ECU has different internals. The EPROM chip will only work in a 90-91 PM6. I would not recommend reving up to the 9000 RPM range of these chips considering the PM6 redline is 7100 RMP. On stock internals you will blow something up and you willl end up with this and this
Old Jan 25, 2003 | 03:40 PM
ScottEK's Avatar
I have two for sale if anyone needs one, just a note, my ecu out of my 90' Si is dated 1989 on the ECU.
Old Jan 25, 2003 | 04:23 PM
89civicdx's Avatar
Default Re: 88-89 and 90-91 si ecu (beta13)
In canada the if you use a 88 or 89 si ecu in a 90-91 si body you will get a electric load detector code as the 90-91 cras don't use a electric load detector
MtnCRX
10
Feb 11, 2005 03:02 PM
wpgcivic
11
Jan 20, 2004 07:41 PM
89dxhunchback
Jun 28, 2003 01:30 AM
Red_Si
May 1, 2003 11:43 AM
Aphrodavid
Dec 17, 2002 07:20 PM
