Battery Tie down problem with lightweight battery?
Old Jan 25, 2003 | 10:12 AM
RTW DC2R's Avatar
Default Battery Tie down problem with lightweight battery?
I recently picked up a T1R lightweight battery, and that thing is tiny. Anyway, my battery tie down(I guess its the stock one as far as I can tell) wont screw on tight enough to secure the battery. Anyone else have a similar issue and what did you do to secure the battery?
Old Jan 25, 2003 | 10:13 AM
Dave-ROR's Avatar
Default Re: Battery Tie down problem with lightweight battery? (RTW DC2)
duct tape y0.
Old Jan 25, 2003 | 10:16 AM
RTW DC2R's Avatar
Default Re: Battery Tie down problem with lightweight battery? (FyrStarter)
Im trying to keep it as non-ghetto as possible...
Old Jan 25, 2003 | 10:17 AM
Dave-ROR's Avatar
black duct tape yo
Old Jan 25, 2003 | 10:18 AM
D's Avatar
D
cut more threads in the tie down j bars yo.
Old Jan 25, 2003 | 10:28 AM
RTW DC2R's Avatar
Default Re: Battery Tie down problem with lightweight battery? (D)
i dont have a thread cutter y0!
Old Jan 25, 2003 | 10:32 AM
D's Avatar
D
go buy/borrow a tap and die set yo!
Old Jan 25, 2003 | 10:43 AM
RTW DC2R's Avatar
I fixed it y0
Old Jan 25, 2003 | 10:51 AM
Rboosted717's Avatar
for a clean fix use a stack of small washers on the metal tie down rods then put the nut on top of them to tight the battary down.
Old Jan 25, 2003 | 11:01 AM
Dropspeed's Avatar
Default Re: Battery Tie down problem with lightweight battery? (Rboosted717)
Man you guys are Ghetto Take the existing battery tie-down brackets ( the metal rod) and measure the length you need to shorten the rod. Mark the spot on the lower end of the rod (the curved end), add about 3/4 of an inch to the marked spot and cut the curved end off. Stick the non-threaded end in a vise and bend it to match the factory curve. Reinstall. Now you have the tie-down without the threaded end sticking up 2 inches above the battery. YO
Mattj
[Modified by Dropspeed, 9:20 PM 1/25/2003]
Old Jan 25, 2003 | 02:04 PM
Johnny Tran's Avatar
b3st thread evAr....
Old Jan 25, 2003 | 05:28 PM
sackdz's Avatar
Default Re: Battery Tie down problem with lightweight battery? (Johnny Tran)
swed yo.
Old Jan 25, 2003 | 08:23 PM
DB2-R81's Avatar
25 Year Member
Default Re: Battery Tie down problem with lightweight battery? (sackdz)
If you want a pretty set up get one of these brackets from Holley. Please excuse the picture size.
[Modified by DB1-R81, 9:25 PM 1/25/2003]
Old Jan 26, 2003 | 01:51 AM
NunRacer's Avatar
Default Re: Battery Tie down problem with lightweight battery? (DB1-R81)
That looks like a nice setup but I don't think it can work with the T1R battery since the terminals are at the top of the battery.
Old Jan 26, 2003 | 02:12 PM
Jaker's Avatar
Default Re: Battery Tie down problem with lightweight battery? (NunRacer)
You gotta do it this way man. Ignore the rust, leaky taillights. I bought the car this way, and haven't had the chance to fix that part up yet.
Old May 14, 2003 | 09:36 AM
skafia's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DB1-R81 &raquo;</TD></TR><TR><TD CLASS="quote">If you want a pretty set up get one of these brackets from Holley. Please excuse the picture size.
[Modified by DB1-R81, 9:25 PM 1/25/2003]</TD></TR></TABLE>
Is it me or does his OE front bar look like its hollowed out? WTF?
Old May 14, 2003 | 09:56 AM
98type_r's Avatar
New User
Default Re: Battery Tie down problem with lightweight battery? (skafia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skafia &raquo;</TD></TR><TR><TD CLASS="quote">
Is it me or does his OE front bar look like its hollowed out? WTF?</TD></TR></TABLE>
its just you
Old May 14, 2003 | 10:05 AM
len's Avatar
len
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">I recently picked up a T1R lightweight battery, and that thing is tiny. Anyway, my battery tie down(I guess its the stock one as far as I can tell) wont screw on tight enough to secure the battery. Anyone else have a similar issue and what did you do to secure the battery? </TD></TR></TABLE>
Are you sure you are turning the nut the correct way?
Old May 14, 2003 | 10:07 AM
RTW DC2R's Avatar
Default Re: Battery Tie down problem with lightweight battery? (len)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len &raquo;</TD></TR><TR><TD CLASS="quote">
Are you sure you are turning the nut the correct way?</TD></TR></TABLE>
I dunno, you are the one that plays with nuts so you tell me lol
Old May 14, 2003 | 10:08 AM
RagingAngel's Avatar
I have the T1R battery and have experienced no such issues.
the two battery tie down threaded posts have enough length/thread to tie down a battery probably another size down!
Old May 14, 2003 | 10:11 AM
Qwikrex's Avatar
Default Re: Battery Tie down problem with lightweight battery? (98type_r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98type_r &raquo;</TD></TR><TR><TD CLASS="quote">
its just you</TD></TR></TABLE>
No, It is hollowed out. I'm pretty sure thats a comptech strut bar.
Old May 14, 2003 | 10:59 AM
skafia's Avatar
25 Year Member
Default Re: Battery Tie down problem with lightweight battery? ([VTEC]TL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [VTEC &raquo;</TD></TR><TR><TD CLASS="quote">TL]
No, It is hollowed out. I'm pretty sure thats a comptech strut bar.</TD></TR></TABLE>
Just checked comptech's website and their bars look almost like OEM. The one that is hollowed out wasn't on their website. Weird. Wouldn't that make it weak?
Old May 14, 2003 | 12:26 PM
len's Avatar
len
I dunno, you are the one that plays with nuts so you tell me lol </TD></TR></TABLE>
******, I'M GOING TO BURN YOUR CAR.
hyperkick
Audio / Security / Video
11
Jun 9, 2010 05:36 PM
patrickstar
Jul 15, 2009 04:38 PM
Turbo_Mike
Apr 30, 2006 06:25 AM
crashtest Sonny
Oct 8, 2002 05:43 AM
