my ghetto POS+salt= =(
rear stealie
amber corner
hood, check out the squirrel and bird pooooooo!
home depot lip (i scraped off my OEM one somewhere and its location is unknown)
[Modified by MrJasey, 6:23 PM 1/25/2003]
[Modified by MrJasey, 1:20 AM 1/26/2003]
amber corner
Guest
Posts: n/a
If you wash it and its below 20 I suggest you do not lock your doors. Unless you don't want to be able to open them again. Just a tip.
You must be proud!
You live by the ocean? You realize how bad salt is for your paint and adding to rust!
for those of you that dont get snow covered or icey roads, they use salt to keep the roads from freezing. the ice/snow turns to slush, and the mix gets on your car. unless you wash your car as often as you brush your teeth, its gonna look like that or worse.
lip don't look that bad... you just gotta keep it straight.. it actually looks better than most body kits.. and other add on lip...
haha if you look at all the people who are throwing negative comments at your car because its dirty they live in areas where snow is basically non-existant.
If they would only understand......
My car looks just as bad, if not worse then yours right now and if you knew me Im the most meticulous person when it comes to keeping my car clean, you just cant avoid it in this weather. Especially when temps reach below zero and the moment you spray water on it it freezes within minutes.
