can somebody help me out with a exhaust gasket??? I can find this shiznit anywhere!!
Guest
Posts: n/a
I recently put my JDM header in and my test pipe and had to replace the gasket that connects the test pipe to the B-PIPE. The gasket that came with the APEXI-DUNK exhaust was a 3-POINT gasket and it really sealed good but now i went to all my local shops and nobody has this gasket so i used this O-RING gasket which is already leaking and smells like ****!!
If somebody has this gasket laying around could u please send it to me so i dont die from carb monixide!! You can Email me @ Wallsofsteven@aol.com or AIM me @ Wallsofsteven!! Thanks!!
I had a few in my trunk, i think i gave one to Riceboi Alex (TypeR 599) when we put on his header, and i think i just threw the other one way, I'll have to check.
Guest
Posts: n/a
I checked every muffler shop possible any none of them had them! Cmon somebody has to have 1 of these laying around because i dont know how much more i can drive my car breathing in these toxic exhaust gasses!!
i got mine at advanced auto parts.
And still has not put it in , and went and dyno'ed today with a exhaust leak.....
The gasket that came with the APEXI-DUNK exhaust was a 3-POINT gasket and it really sealed good...
You can get a gasket at either http://www.summitracing or http://www.jegs.com . I'm using the gasket from Jegs and it works perfect for me.
Jegs website was down, but I did find the gasket on Summit's website. Here is the link: http://store.summitracing.com/partde...57#largerimage
HTH
pepboys sells them for about 2 bucks they sell the same(or similar to) gaskets that came with my JIC cat back
and understand, that with a test pipe the smell will not be going away with the gasket, it will simply be going out at the end of the car. With your windows down and the wrong wind at a stoplight, you will still die from the foul stench. And Dave at SMSP carries the correct ones also. IM him.
3, advance, auto, exhaust, gasket, gaskets, geocities, leak, pipe, skunk2, surferx, teamintegra, teamintegranet, teamintegranethow, test
